red hot manifold???
Old Mar 29, 2003 | 05:29 PM
Juicey's Avatar
red hot manifold???
i just rebuilt the top half of my camaros engine. (its a 2.8 v6) and i finally got it all together the other day. when i went to make sure everythign was in working order the engine wasnt able to push more than 20 mph and very poorly at that, and upon opening the when i got it back to the driveway i noticed that my exhuast manifolds were cherry red from heat. does anyone know why they would be overheating so much
Old Mar 29, 2003 | 06:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
IIRC, that is a lean condition
Old Mar 30, 2003 | 07:44 PM
25THRSS's Avatar
That is VERY lean, i would richen that baby up right away! Could be the timing also, but check to see if its getting enough fuel first.
Old Mar 30, 2003 | 09:57 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do you have a cat? Was it glowing? A clogged cat will cause loss of power and IIRC reddish manifolds.
But, would definately look for a lean condition and check your timing.
Old Apr 6, 2003 | 09:43 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sounds like timing is way too retarded.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 07:28 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
