Ground clearance
Old Nov 15, 2001 | 08:45 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Ground clearance
I was wondering how much ground clearance do you guys who have cat-backs and you car lowered, have?
I let my car back down on the ground a few days ago after having it on blocks for a couple of months. During that time I've installed a complete exhaust system, and it seems mighty low? I can't see anywhere to adjust it to get it higher though...?
Ken
1986 IROC-Z Conv't
- White Gauges, 17x9.5 TT II rims w/275/40x17" F1s, 1.5" Jamex Lowering Springs, BMR stb, Lakewood APR, PST suspension parts, Edelbrock Trailing Arms, KYBs, Edelbrock RPM Cat-Back, Edelbrock JHC Headers, Catco, World Products Heads, CompCam, SLP runners, Ported Plenum, K&N, Airfoil +polished/billet dress-up stuff
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Nov 15, 2001 | 11:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ken, Ive talked to a couple low rider guys (non thirdgen) and asked about ground clearance before I had my duals installed. One of the guys had no problems out of the ordanary the other had to get his pipe ovalized. (heat up and flatten bottem of pipe)Usually with a catback there should be no problems because its in the same area as the stock pipe just side by side. I would take it easy on the streets for a while and just fine the places where you car will bottem out and avoid them. yea common sence stuff but its all the advice I can give ya.
Good luck!
SSC
Edit: Damn, sweet convertabel!!!
85 Camaro, 355/400 "drag car" current DD 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firbird, rebuilt 355 for it and slaped a 700r4 in. The 700r4 crapped out so back to the tb350
[This message has been edited by SSC (edited November 15, 2001).]
Old Nov 16, 2001 | 10:14 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
SSC,
Thanks for the thumbs up on my car
Yeah, the cat-back goes in the stock location, but I can't recall the stock exhaust being as low. But then again, it has been a couple months since I ripped off the original exhaust, so I might be wrong...LOL
Thanks for your inputs!
Anyone else have ground clearance problems with lowered car and 3" catback?
Ken
Old Nov 17, 2001 | 10:15 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by ChevyKen:
Ken
</font>
I dont have mine lowered but, with one of the clamps that hold my exhaust together, it is only 2 1/4" off the ground. The pipe itself is about 2 3/4" at its lowest spot.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
Old Nov 20, 2001 | 01:35 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
hey ChevyKen, I also have an Edelbrock RPM Cat-Back on my 82 Z28 and know what you are talking about with the ground clearance. The I-pipe is about 3-4inches from the ground! As far as i know, there is no easy fix. Just gotta drive slowly over speed bumps :\
Old Nov 21, 2001 | 01:11 AM
JunkHead84's Avatar
life the back of the car and give it that old muscle car look.
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Thaney9
Oct 24, 2015 07:26 PM
91 SrS
Oct 7, 2015 04:32 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
