Help - Exhaust set-up
Old Nov 20, 2001 | 03:00 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I was about to order the Edelbrock TES headers and the Edelbrock RPM series cat-back system but I was not sure which ones to order for my car. I have a 92 RS 305 TBI and I want to upgrade the exhaust (headers, catalytic converter, cat-back system) to 3 inches. The headers for my car has the 1 5/8 primaries which is what I need but only has a 2 1/4 collector, do I need an adapter for this to fit a 3 inch inlet/outlet cat? Now for the cat-back, there are 2 choices, one is for camaros with the stock 2 3/4 inch I pipe and the other is for camaros with the stock 2 1/2 inch I pipe and both has the 3" inlet and dual 2 1/2" outlet. My issues are:
1) will these headers only work with my stock catalytic converter, what if I want to change to a 3" inlet/oulet cat will they still work
2) can I use the headers for a 1990 IROC 5.0/5.7 TPI which has the 3" collector on my 92 RS 305 TBI
3) why does it matter what size I pipe my car has, isnt it going to be replaced with a 3" pipe that is included with the cat-back system
Please advise, I really want to upgrade my exhaust but I just want to make sure that I order the right parts.
Thanks in advance for your inputs!
  • 92 CAMARO RS 305 TBI (PURPLE HAZE METALLIC)
  • 700R4 TRANNY
  • EDELBROCK 14 X 3 OPEN ELEMENT AIR CLEANER
  • EDELBROCK ELITE SERIES VALVE COVERS
  • ALPINE 7858 CD PLAYER
  • DHD 4 CH 400 W AMP
  • MTX 5 1/4 COMPONENT (FRONT)
  • MTX 6 X 9 (REAR)
  • FUTURE MODS:
  • EDELBROCK TES HEADERS
  • CATCO DIRECT FIT CATALYTIC CONVERTER
  • EDELBROCK RPM SERIES CAT-BACK SYSTEM
  • HYPERTECH 180* THERMOSTAT
  • HYPERTECH 180* FAN SWITCH
  • TRANSGO SHIFT KIT
[This message has been edited by Js91RS (edited November 20, 2001).]
Old Nov 20, 2001 | 04:49 PM
Tas's Avatar
Tas
Just get everything for teh TPI. Go full 3". The only thing that won't work with the TBI is that you wont have the heat riser on the drivers side exaust. Its not a big deal though. You could probably take the stock one off and tack weld it there for inspection time.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 21, 2001 | 12:27 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
Tas, do you think that the TES headers for a 1990 Z28 would fit my 92 RS? These headers have the 3" collector(y pipe). The other set that they have for a 1990 RS is the same as for the 92 RS so I think that they should fit. What do you think?
  • 700R4 TRANNY
  • MTX 6 X 9 (REAR)
  • FUTURE MODS:
  • CATCO HI FLO CATALYTIC CONVERTER
  • TRANSGO SHIFT KIT
[This message has been edited by Js91RS (edited November 21, 2001).]
Old Nov 21, 2001 | 01:25 PM
Tas's Avatar
Tas
they both fit but the size of the pipes are different and the TPI headers don't have the heat riser on them. The TPI headers have dual 2.5" Y pipe to single 3". TBI headers have dual 2.25" to single 2.5". I got the TPI headers made by hooker. Dual 2.5" Y to single 3"
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Nov 21, 2001 | 01:56 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
</font>
Thanks Tas, I will go ahead and go with the Edelbrock TES headers for TPI equipped engines. Just curious, did your hooker headers come equipped with a Y pipe and all the necessary hardware?
Old Nov 21, 2001 | 07:07 PM
Tas's Avatar
Tas
ya they came with the Y pipe and all hardware but I got better aftermarket gaskets to replace the cardboard ones.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
Fred SS
Oct 12, 2015 11:27 AM
david068513
Sep 18, 2015 10:36 AM
64goatman
Sep 9, 2015 01:09 PM
