HOW EASY IS IT TO REPLACE THESE?
Old Nov 23, 2001 | 01:07 PM
1986CamaroIROC-Z's Avatar
I have an 86 IROC 305 TPI, and I just found out that it has an exhaust gasket leak. I wnat to replace the exhaust gaskets, and am wonderin if this is something i should do myself, or let the mechanic handle it. What sort of tools would I need, and would I need a lift or anything. Please give me your opinions.
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 23, 2001 | 01:22 PM
cobrakiller1989's Avatar
If you ask me, you should save up a few dollars and put headers on at the same time. Your already gonna have to remove everything. Just put headers back on instead of manifolds. Just my $.02
As far as tools go, you would just need wrenches and rathets. If you dont have a lift a jack and jackstands will do fine. Some PB blaster or wd40 for stubborn old bolts might help too
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
"There is no way you have a 350 in that car. They are made to have 305's and a 350 wouldnt fit"
-local parts store genius-
Old Nov 23, 2001 | 02:33 PM
hot89camaro's Avatar
depending on where you live (snowy climate or not), the exhaust flanges bolts etc may be extremely rusted. If they are, you will be lucky to get them all broken loose, and taken out without breaking them. It is NOT a fun job if they are rusted badly. My suggestion is to go to a local muffler shop, and they would PROBABLY do it for about 20 bucks, money well spent in my book.
89'rs
400 Small Block
10.2:1 AFR Heads
427 hp, 454 ft/lbs
Old Nov 23, 2001 | 02:43 PM
thanx for the input. I want to get headers eventually, but not until the summer. If it only costs 20 bucks or so, sounds like a good deal...worth it if it doesnt involve me bustin up by knuckles and cursin all damn day. THe clickin noise its causin is extremely annoying.
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
BurlyChev
Aug 16, 2015 09:08 PM
TheJoeY88
Aug 13, 2015 06:51 PM
Fronzizzle
Aug 9, 2015 01:15 PM
