what should i do when installing cut out?
Old Nov 23, 2001 | 11:36 PM
breathment's Avatar
ok, so what steps are involved in intalling a cutout? how do i slip it on? do i have to remove one section of the exhaust so that i can slip it over both sides? does anyone know what im talking about?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 24, 2001 | 04:04 AM
Jza's Avatar
Jza
Cut out a section of pipe the same length as the cutout. Then either A) tack it on, then weld it up or B) cut a short length of pipe with an ID slightly larger than the cutout's OD, and slip it over one end, weld it up, then slip it over the end of the car's pipe, weld it up, then weld up the other side of the cutout. That's not the greatest description, but it's 4 in the morning and I'm going to bed now. I did plan B. It insured the best seal and straightest installation since tacking two butt-to-butt pipes perfectly straight is not easy.
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
TheJoeY88
Aug 13, 2015 06:51 PM
mustangman65_79
Aug 13, 2015 07:36 AM
TA8487
Aug 11, 2015 09:02 PM
