need some header help
Old Dec 11, 2001 | 05:22 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
What headers can i install and also (this will be for the strip only) what recommendations on exit location?
Thanks!
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old Dec 11, 2001 | 05:39 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
what do you mean what headers can you install? you can get any ones you want...
are you looking for full lengths? you said that they are only for the track so you may want to look into them.
if not i would definitley recommend SLP stainless 1-3/4".
-brian
1991 Camaro RS
GMPP 350 HO crate engine w/TBI
Homepage z28boy@twcny.rr.com AIM - "Z28 Boy"
Old Dec 11, 2001 | 05:40 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
oh yeah...the SLPs will bolt up to your stock cat-back, and with full length i think that you usually let them dump right at the end of the header (small mufflers under the floorboards) or you can run true duals all the way back.
-brian
Old Dec 12, 2001 | 11:34 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Yes, I'm looking for full length, 1 5/8 or 1 3/4
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
