flowtech header questions 11102flt
Old Apr 10, 2003 | 11:59 AM
blk86ta's Avatar
I just picked up some flowtech headers part no 11102flt...they were only 63.00 through pep boys(I dunno how or why, they are like 120-160 everywhere else). Anyways, I havent ordered the y pipe yet but on the instrustions it says I can use my stock collectors....I wanted to verify that before I got everything apart.
also, they don't have the AIR holes...no big deal really, I'll just swap in my manifolds for emissions unless-would it be unwise to tap the holes into the headers? does that do anything for the stability of the header? thanks,
Jason
Old Apr 10, 2003 | 05:56 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Take my advice and don't get the y-pipe. I have it and it flows terrible. The stock pipe probably flows better. I am cutting it up and welding two pipes together to improve it.
Old Apr 11, 2003 | 12:41 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
You cant use your stock pipe unless you weld on the collectors to the stock ypipe, that flowtech give you with the headers. But im not sure if you would need to do any custom bending to make it fit. I wasnt going to mess around i just wanted a direct bolt on so i got the ypipe too. The flowtech ypipe isnt the best out there but its not a ****y pipe buy anymeans. Mine fit perfect! the only thing i didnt like was that it wasnt painted and that the Y part is more of a T. But its not like I have the full mandrel 3'' pipes behind it anyhow so thats the least of my "flo" worry. All in all Im happy with my set up. If I wanted a little better I would of went and spent 3times as much on the other brands.
Old Apr 11, 2003 | 03:38 AM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
I am just saying if you have a built motor, it might become quite restrictive. Other brands kind of run two pipes into one which is what a y pipe should do. This one is just a T. On a basically stock motor it will be fine. You're right, it does fit perfectly. I've had no problems installing and removing it.
Old Apr 11, 2003 | 10:38 AM
blk86ta's Avatar
kew
I ended up ordering the y pipe last night so I wouldn't have to dick around with it. it just got here
Old Apr 12, 2003 | 07:07 PM
Car: '81 Trans Am
Engine: 6.6L
IROC315- yes your right very tru!!! If you got a nice suped engine a different y would be alot better!
blk86ta- let us know when you get it on and how you like it?
Old Apr 2, 2010 | 12:49 PM
estesformula87's Avatar
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: kew
i bought these for my 87 formula 305 tbi and every thing was a direct fit y pipe and all they are oem direct replacement
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
