A.I.R Removal quick question
Old Apr 20, 2003 | 03:54 PM
lowprofile's Avatar
I am in the process of removing the smog pump and the associated garbage, got the pump off and hafl the air tubes on the pass. side.
My question is How do I remove the metal Tubing that runs behind the engine and connects the passenger and drivers side air tubes together?
Josh
Old Apr 20, 2003 | 04:40 PM
lowprofile's Avatar
forgot to mention 85 iroc 305 tpi
Old Apr 20, 2003 | 04:51 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Well, it's quite simple, just need to pull the engine out of da car
Old Apr 20, 2003 | 09:00 PM
25THRSS's Avatar
Does anyone know? I will be doing this very shortly as well.
Old Apr 20, 2003 | 11:44 PM
lowprofile's Avatar
it almost seems like the motor needs to come out for this... but there has to be another way
Old Apr 21, 2003 | 12:20 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
there should be a rubber hose thats what mine had the one going down to the cat i just left open
Old Apr 21, 2003 | 09:04 AM
lowprofile's Avatar
there is one going to the cat, and another going to the drivers side, its kinda big and will look tacky left in there. I could see leaving the cat "pipe" for lack of better term but the other tube needs to go.
Old May 1, 2003 | 11:53 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
14 mm wrench fits on the bolt thats on the pass side head.
Old May 2, 2003 | 11:18 PM
ctandc's Avatar
Good luck getting the pipe out that goes around the back of the engine. I cut it off as far back as I could, then when I swapped the 5 speed out, I yanked it when the tranny was out.
There's no room to get it out, at least, I sure as HECK didn't have the patience to screw with it anymore than I did.
You couldn't see it with it cut off anyway.
HTH
Old May 3, 2003 | 12:36 AM
lowprofile's Avatar
ya it does look rather tight back there ! I think I am going to go the cutting route also.
Old May 3, 2003 | 10:20 AM
87transam5.7tpi's Avatar
I took mine out by cutting it and then fishing it around till it came out.
Josh
Old May 4, 2003 | 12:00 AM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
It is a major pain to get done, & I managed to break something when I did it.
I took a hack-saw blade by itself on the passenger side & got what I could out that went down toward where my converter used to be.
Next, I started trying to work out the part that goes around the back by the firewall & after a bit became sort of frustrated with the lack of progress.
I pried on it & thought it was coming out without hitting anything, but when I started the car (after plugging all of the air exhaust manifold holes), I noticed oil squirting straight up from the back of the engine compartment. I had snapped off a little fitting that was possibly the oil pressure send unit, but whatever it was I ended up have to use an EZout to get the piece that was still in the manifold & then replace the fitting.
If I had it to do over again, I think I would try using something like a dremel tool which is small & reach back farther than what I could with the hacksaw blade.
Good Luck!
Old May 5, 2003 | 06:25 PM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
I drive a bone stock IROC with the L03/T-5 combo, what kind of power gains could I expect just by removing the smog equipment?
Old May 5, 2003 | 09:18 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
nothing noticable except saving 15 lbs or so off the front end
Old May 6, 2003 | 05:06 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Technically there would be a gain seeing as belt driven accessories can draw *up to* 14hp or so. As far as the tube; just chop 'n' yank man, I happened to have the motor out so I cheated, but it sounds like you should be able to get it out regardless. Good luck.
Old Mar 10, 2004 | 12:12 AM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
Could you post pics and supply details on how and what parts to remove when eliminating the AIR pump.
Thanks in advance.
Old Mar 10, 2004 | 01:10 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I just bought a serpentine setup for my car (I have already removed all my air smog stuff when I replaced the engine), the first thing I did to the serp setup was to take the air pump apart and take the guts out of it so it turns more freely. If you do this, just take the back off (4 or 5 bolts), remove the back plate, and inside you will find two composite vanes. I cut/broke them off and pulled them out and then put the pump back together. I just did this because 1. it cost no money and 2. I didn't want the open space in my acc. bracket.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
jahblah
Aug 12, 2015 05:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
