Block the AIR tubes?
Old Apr 28, 2003 | 04:20 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Will blocking my AIR tube at the cat end cause any problems with exhaust flow at the manifolds or with the AIR pump??? I'm running without a cat and want to keep the tube for my next etest in place but dont like the leaky exhaust sound it gives off sometimes.
Old Apr 28, 2003 | 04:41 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
You can block it off. It's not going to hurt anything. Is your emission test just a visual test? If it's just visual, you can block up the inside of the tube then hook it back up. That's what I did to mine, but Virginia only has a visual inspection.
Old Apr 28, 2003 | 04:47 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
It's visual + probed at idle and 40km/hr I dont have to etest again till next year tho.
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
theurge
Aug 21, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
drathaar907
Aug 6, 2015 04:20 PM
