Plug access and lt headers?
Old Apr 28, 2003 | 10:15 PM
mastrdrver's Avatar
Is there a lt header that has good plug access? I have seen people have problems with getting plugs in/out with hookers, headman, etc. Is this bcuz of straight plus or do these also have angled plus?
Jeremy
Old Apr 29, 2003 | 05:17 PM
mastrdrver's Avatar
Anyone have any comment? Is there a lt header that doesnt require short plugs at all?
Old May 3, 2003 | 11:35 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I have Hedman LT's and plug acces is not bad at all, most of them I can put a ratchet on without even an extention. There are a couple of plugs that I have to use an open end wrench on but it is a hell of a lot easier than it was with the stock manifolds! I used to have to jack the car up and crawl under it to get to some of them.
Old May 4, 2003 | 08:37 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I could use regular plugs with the hooker shorties i had. I just use a socket and a wrench on the end. With my hedman LTs #5 ankd #6 are a PITA. I cant get a socket on the delcos at all. Thats why i usually run accel header plugs. They seem to work good but the tips come off easy. I found a place selling them for 15$ a set so that isnt bad. Advance sells them for 30$
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
mdtoren
Aug 23, 2015 12:52 PM
