Making headers- flange material? Pipes?
Old Apr 29, 2003 | 04:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hello all; just wondering, if I were to make my own headers, what kind of steel is adequate for the flange material? Home Depot sells strip stock; I can get it in 3/16" thickness- can't imagine how to DRILL that, but- would it hold up to heat okay? I assume it's just regular strength steel; just wondering if it'd warp to hell.
Would regular 'ol exhaust pipe work for the primaries?
I can't buy a "weld your own headers" kit, because I have a v6.
I suppose I might be able to "drill" the flange by cutting it apart into sections, and welding it back together. Think that'd hold up okay to heat? My welder is a MIG, I use a C25 mix.
Old Apr 29, 2003 | 05:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Most headers are made from standard mild steel. Home Debt flat stock is fine.
A hole saw and a drill press would be the best route for making the holes. A hand drill will work but is a bit more difficult.
Thin wall EMT condiut works pretty good for tubing and you can buy it pre-bent 90º. I believe Home Debt also carries these up to 2".
A 3" to 2½" reducer flange set work pretty good to tie the tubes together. It's just a matter of tacking and hammering to get it to conform to the tubing.
I did this for a friend when the manifold on his old crappy 4cyl GLX split in half (literally). Is was much easier than hunting one down and, it turned out pretty good for the hour I invested in making it. Last time I heard, it's still in service as a j-yard car somewhere in Colorado.
Old May 5, 2003 | 06:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool! Thanks (yet again), Deadbird!!!
Old May 6, 2003 | 07:14 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You could save some time & frustration by buying the flanges already made & welding on your tubes.
Old May 8, 2003 | 02:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do they even -have- those for the 2.8/3.1/3.4 v6?? (As I said before, I have a v6.) I didn't think any company would bother with making a flange for this motor...
Old Aug 9, 2003 | 05:40 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
so why are you you should be fine with mild steel
87iroctheo
Dec 4, 2016 11:47 AM
lt1z350
Aug 28, 2015 05:57 AM
Bstrang6
Aug 26, 2015 11:39 AM
Golfvette
Aug 24, 2015 06:35 PM
Chiknhawk
Aug 23, 2015 05:54 PM
