Broke a head bolt what are my options?
Old May 10, 2003 | 11:18 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I got my old manafolds and y-pipe off. But I got one bolt broken off in the head.
Im Curious what my options are dp i have to pull the heads off and get them fixed. If so how much would that cost.
Should I go ahead and order the 330hp crate from gm?
I dont want to put to much money into the engine itself cause I had been plaining to replace it.
the slp headers and y pipe looks like they will make a huge improvment over the stock.
Old May 10, 2003 | 12:09 PM
Camarokid01's Avatar
Im sure there is a way to get it out with the heads still on the car, but if you take it to someone to take out it wont cost you anymore than like 30 bucks
Old May 10, 2003 | 12:15 PM
firestarter's Avatar
Car: 86' camaro s/c
Engine: 357
Transmission: th350
Go to the local auto parts dealer and get a bolt extractor. Its not expensive and you can do it w/ the head still on the car. Basically you drill a tinny hole in the broken bolt. Then a little bigger hole. Then you insert the bolt extractor into the broken bolt and use a wrench to back the bolt out. That simple.
Old May 10, 2003 | 03:30 PM
91RS5speed's Avatar
Car: 91 RS
it's the one all the way back on the drivers side so i cant get a drill on it. So off the tpi come and then the head.
Old May 10, 2003 | 05:40 PM
crazycrocket's Avatar
Car: 1985 camaro
IN that case, port them heads while you gots em off
Old May 10, 2003 | 10:56 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Re: Broke a head bolt what are my options?
Depends. Were you planning to replace it next month or next year? Would it be more convenient to replace the engine now or later? If you do the swap now, will it affect things like food, shelter, other necessities?
If it were mine and money was not the primary concern, (usually is for me) and I didn't have to drive it to work tomorrow, I'd probably be tempted to swap it out as you are.
Just some things to consider...Do as you like.
evilstuie
Jan 9, 2020 08:29 PM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Amillionoh7
Aug 7, 2015 01:24 PM
