cat removal
Old May 20, 2003 | 01:27 AM
ceaser76's Avatar
cat removal
I'm new to high performance cars, just bought my first camaro. An '83 z with 63k miles. I've had a flowmaster w/ 3" pipes put on but am considering having the cat removed. No emissions testing to worry about, but will it make the ses light stay on all the time? A guy I work with had that done to his 2003 mustang and it is always on.
Old May 20, 2003 | 01:46 AM
25THRSS's Avatar
no, it won't effect anything.
Old May 20, 2003 | 01:52 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Most any car built after 1994 has to be OBD-II. Which means the computer has to monitor the emissions & correct. This is done by having two O2 sensors, one before the converter & one after. If you remove the converter it will push the O2 level down too low & the system will not be able to compensate for it, throwing on the SES light. Third gens don't have this system, so no problems with removing the cat, as long as no emissions inspection is required.
Old May 21, 2003 | 12:48 AM
ceaser76's Avatar
Thanks for the info. I didn't think it would cause the ses light to come on in a car that old, but it never hurts to be sure. Does it really add any hp or deeper sound?
Old May 22, 2003 | 08:56 AM
Beefy89's Avatar
I don't know if I gained any power,because I had rebuilt the engine and added some things when I removed my cats,but it is LOUD!!!!!!
If I drive normal it's not too bad ,but when I step into it,it gets alot of attention..
Old May 22, 2003 | 06:56 PM
MCas7's Avatar
If you ses light comes on, just smash the bulb. That always worked for me. And funny enough, it never came back on.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
