Can a stock y-pipe be modified to be used with long tube headers???
Old May 20, 2003 | 09:10 PM
Berlinetta82's Avatar
Can it? I have access to a welder(and a welder) and a tubing bender if needed. I know it is likely posible but is it worth it. Have any of you done this?
Can I see some pics of you exhaust set ups? Not duals because that's not what im thinking of at this point. But long tube headers with the single pipe to the muffler.
Old May 20, 2003 | 10:11 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
It would be a real hack job. If you have access to a welder and a pipe bender, i would fab your own Y pipe. Stock Y pipes are absolutely aweful, and if you are going to go to the trouble of longtubes you might as well take the next bottleneck (crappy y pipe) out of the exhaust .
Old May 20, 2003 | 11:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Here's what I did with my long tubes. Used the Hedman S extensions.
Off the passenger side there is a straight pipe into a flowmaster y collector, off the driver side there are 2 45* angle pipes into the otehr side of the y collector. The collector hooks right into my Hooker cat-back.
Old May 20, 2003 | 11:52 PM
Any pics of that set-up Mark?
Old May 21, 2003 | 09:02 AM
Car: 99 Formula
Axle/Gears: 342
None that came out clear enough
Old May 21, 2003 | 12:13 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Mark A Shields
lmfao...sorry i had to lol
Old May 21, 2003 | 12:43 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by f-crazy
Mark A Shields
Old May 21, 2003 | 01:37 PM
MCas7's Avatar
I have hooker long tubes and a y-pipe on my car. I had the y-pipe custom made and I just ran the Intermediate pipe down the center of the car on the passenger's side of the driveshaft. It is a factory int. pipe with the bend for the cat cut off. I have some pictures but I don't know how to post them.
Old May 21, 2003 | 04:25 PM
Could you email them to me?
Old May 21, 2003 | 05:50 PM
Momar's Avatar
So what made you decide against true duals? How much clearance do you have? How far back does the pipe cross over from the drivers side?
Ben
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
