May 26, 2003 | 04:08 PM
right now i have shorties on my car, it baackfires a few minutes after running, im wondering if this is normal due to no back pressure, or is my timing off? the hedders are not hooked up to anything,.
Reply 0
May 26, 2003 | 04:59 PM
Open shorties? Could be either one. Check timing, check firing order, hook up exhaust...
Reply 0
May 26, 2003 | 06:53 PM
do you have anything hooked to the headers?
Check timing and make sure no plug wirs are crossed.
Reply 0
May 26, 2003 | 11:06 PM
thanx guys, im wonderin if it could be my firing order, i had a shop do some work and they may have crossed the wires, i need a diagram of the proper order that i should place the wires on my cap, it would help, thanx again.
Reply 0
May 27, 2003 | 12:29 AM
No problem.
Reply 0
May 27, 2003 | 12:47 AM
thankyou dan
Reply 0
May 27, 2003 | 04:10 AM
Let us know what happened when your done.
Reply 0
May 28, 2003 | 07:44 PM
well i checked the wires and they are all on correctly. Im thinking that my timing is off coz im runnin too rich, when i had my exhaust on i was getting fumes comin out the pipes. I dunno if thats it but at least i found out that my wiring is good.
Reply 0
May 28, 2003 | 09:11 PM
check your spark plugs. They might be fouled. If you are running rich like you said, then there is a chance that one of the plugs is fouled.
Reply 0
May 29, 2003 | 12:38 AM
but i just installed new plugs recently
Reply 0
May 29, 2003 | 02:25 AM
That's okay, a car running rich can waste no time fouling up plugs.
Put go ahead and fix the timing as that's alittle easier than doing plugs, right??
Reply 0
May 30, 2003 | 09:24 PM
Backfire through the carb, or backfire out the exhaust? If its through the carb, you timing is probably retarded. Also, make sure non of the ends of the wires have been torn loose.
Reply 0
May 31, 2003 | 01:35 AM
backfire through the headers.
Reply 0
Subscribe
