Stupid (&^#$(*^%%# Mufflex Y-pipe!
Old Jun 13, 2003 | 07:35 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I got the 406 freshen up and put back in the car, have new coated Hooker Super Comps. Went to install the Mufflex y-pipe into their 4" exhaust, doesn;t even come close to fitting.
The flanges on the headers are a good inch higher than the y-pipe can physically go beacuse of the way it is made.
Anyone else have stories to share about this one?
Old Jun 13, 2003 | 09:27 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
could be because the products arent made by the same company? I had bought summit headers and a hedman y-pipe and they dont match.
Old Jun 14, 2003 | 09:07 AM
agchoset's Avatar
Car: 2001 C5 convertible
don't even get me started on that thing
I fought with that piece of poo for over 3 hours yesterday, and I'm still not happy with the way it fits. I can't really blame mufflex for that, though, since I have a T56, and the crossmember is therefore in a different location than the y-pipe was designed for. It just takes a LOT of twisting and turning of the different sections, to get it to line up properly... The thing that helped me was to finally realize that the actual Y section must be positioned such that the pipe with the downward (or upward, depending on how you're looking at it,) angle should be on the passenger's side, pointing down. Then it's a matter of using the other pieces to get the lateral spacing correct so that everything can slip together.
I've got 2 or 3 spots where the y-pipe is right against the crossmember. It's going to vibrate like crazy, but hopefully a muffler shop will be able to tweak it a bit.
Have fun,
Andrew Choset
88 IROC-Z
98 Tahoe LT
Old Jun 14, 2003 | 12:00 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
ive seen on this one guys car he ground down some of the crossmember to give him clearence with the y pipe.
Old Jun 14, 2003 | 12:56 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yea. Problems. It's in the sticky. Point #13.
Tim
88SS6SPEED
Nov 11, 2015 07:05 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
