Ground clearence with Hooker 2055 Y-pipe
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
thanks!
i'll need to take some good/recent pictures, the ones on my page don't do it justice as that great pic of yours does.
also, i'm in sac, you should bring your 'bird when we get a cruise together!
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Off topic i know but my hedmans went in easy as a $5 woman.
anyways and i noticed a BIG bifference also didnt have to take the starter off or lift the engine and you cant even see the y pip i think its as close to the cars body before it would start to rub if it was any closer.Very happy with the headers
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Originally posted by Maverick H1L
This is a little off the toipic, but what would cause a stock y-pipe for the 2.8L V6 to hang that low? I'm having problems bolting up my new cat because of that.
Transmission: 4L80E/4L80E
Reviving an old topic here.
machinist, how did it all come out?
I had my car up in the air today, decided to see if I could tuck mine up a little tighter. I had never hooked up the cat hanger from the LG4, have a borrowed wire welder, so thought I'd give it a try. Loosened things up, held the cat up with the floor jack, welded the hanger to the pipe clamp (they were so close together, you'd think I'd planned it that way), tightened things up again. Much, much better. Also have the piece of mind knowing it's supported properly now.
But, it wasn't nearly as bad as machinist's was before I started.
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
yep mine is just like MetalliCamaroRS maby even lower
and stick someone on the passenger side around 200 pounds and when I hit a nasty road and it scrapes
I look like this-------->
Im so pissed Im thinking of spending the $$$$$ and buying a different setup
and stick someone on the passenger side around 200 pounds and when I hit a nasty road and it scrapes I look like this-------->
Car: 1991 Z-28
Engine: TPI
Originally posted by MetalliCamaroRS
Mine is low as well, here is a pic:
Im going to try and get a pic of mine tomorrow to post
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
zdude.
Sorry for your problems.
On mine the Y pipe is up nice and tight. The photo of your car shows it to be pretty low, but it should not scrape.
If you can get it up on a lift, see if you can add a hanger to pull it up. If not you must have a screwed Y-pipe.
I know it has happend to a few people on this board. I went Holly on the headers and cat back and I can't be happer. My TA is lowered an inch, but not as low as yours.
must be frustrating. good luck
Car: 1991 Z-28
Engine: TPI
Originally posted by Roads88
zdude.
zdude.
I got mine at summit and then sent them off to Jet-Hot.
You can also get them strait from jet hot for a few dollars more.
I seem to recall that one person got the 2055's from Jet-Hot and had a Y pipe problem. also, they worked with him and got the problem taken care of without to much trouble.
your 91 isn't a true dual exhaust? If it is you shouldn't need a Y pipe. Hmmm maybe that was just the 350. I thout after 88 they were true duals.
Hope this helps and good luck.
He never came back to tell us the final outcome. That's why I asked.
