hedman hedders dont fit!!!
Old Jun 25, 2003 | 10:02 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
i bought hedman long tubes but they dont fit.
http://store.summitracing.com/partde...rt=HED%2D68460
i just dropped in a new motor (350) and put the hedders on. passenger side is fine, but the drivers side is hitting on the where the lower control arm connects to the frame. is this a comon problem? i tried to search but didnt see anything. thanks for your help
Old Jun 25, 2003 | 11:44 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Yeah ive heard and seen it on here, the primary hits the top of the k member, just trim it down so it will fit. ill try to find a pic and post it.
Kevin
Old Jun 26, 2003 | 03:12 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Do a search for Hedman longtubes, put 1990GTA for the user name in the search. There should be a post there titled "I have no idea what headers to get..." by 84customZ28, check that post out, I have some pictures of the same headers you have that I just installed. There is even a couple pics of the K-member trimmed, I also had to "modify"the very back primary on the driver side with a BFH to clear a part that could not be trimmed.
Old Jun 26, 2003 | 04:34 AM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=148210
lots of info on there with pics.
Old Jun 26, 2003 | 11:28 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
you'll have to notch the a arm just a little and it will be fine.
Old Jun 26, 2003 | 11:35 AM
cr125r's Avatar
Car: 1988 trans am
ill try that out, thanks
New2Chevy
Sep 28, 2015 12:35 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
