Where is your cut-out?
Old Jul 12, 2003 | 12:55 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
I'll be installing my headers soon, and figured I might as well through a cut-out on so I can be even more obnoxious and loud when I want. I was thinking of putting it right where my cat was, so I don't have to crawl very far under the car to get to it. My buddy with a '00 SS has his right before the exhaust goes over the rear-end. Is there any pros or cons to having it back there? I dont really want to cut into my SLP cat-back, so where should I put it? Also, any heads up/advice you can give to me for when I'm installing my headers? Anything special I have to do about getting rid of the emissions? What about the charcoal canister?
Old Jul 12, 2003 | 02:44 AM
25THRSS's Avatar
That is a good place to put it.
Old Jul 12, 2003 | 06:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
...where the cat was...
Old Jul 12, 2003 | 11:50 PM
MdFormula350's Avatar
yeah definitely put it where the cat was, sounds like the easiest and best area to get to.
i would leave the charcoal (vapor canister) intact.
the only header decision is to have a.i.r tubes or not, and of coarse you need them to have the o2 sensor provision.
i went with slp non air headers, so i deleted the air pump, air hoses, and that black box. all is well after running for over a month.
Old Jul 15, 2003 | 12:11 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Mine are right before the mufflers on my duals setup. Very easy to reach when I want to make some noise.
Old Jul 15, 2003 | 08:37 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I have mine right on the end of the y-pipe b4 the cat.
Old Jul 16, 2003 | 03:10 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Here's mine
Roshambo
Nov 17, 2001 04:21 PM
Roshambo
Nov 11, 2001 07:11 PM
Roshambo
Nov 8, 2001 03:15 AM
mostafa3k
Feb 6, 2001 07:35 PM
Basett Racing
Jan 5, 2001 07:04 PM
