Has anyone run their mufflers like this?
Old Aug 12, 2003 | 11:59 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm researching the idea of true duals, and I'm sure this has probably been posted, but annyway. One main problem with true duals is that the mufflers, mounted under the floorpan, hit the ground. But if they were mounted more towards the rear, like in this pic, wouldn't that solve the ground clearence issue? Or would this cause problems of it's own? Thanks,
Attached Thumbnails Has anyone run their mufflers like this?-kitt-coyote-x-back
Old Aug 13, 2003 | 12:03 AM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
a few people have mounted their mufflers there, id suggest though using glasspacks or bullets coz they wont be offset because the way the trunk sits. If you use normal ovals then the right side will look awkward compared to the left.
Old Aug 13, 2003 | 12:23 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
If I wanted a true dual setup with ground clearance, i would have the pipes come over to the passenger side of the car like they are going to y, but instead have an X pipe, then 2 bullets where the catalytic converter would have been, then into either dump both or merger them into a big turndown.
Old Aug 13, 2003 | 02:02 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hooker makes "mufflers" that actually just hide inside the pipes. Thats what alot of people who hang sidepipes outside of their cars (ie. Shelby Cobra replicas, old Corvettes) do.
I once heard a '69 Corvette with what I think was a small block with a set. Sounded pretty nice, but was fairly loud too. Dunno if its a bad restriction though.
Old Aug 13, 2003 | 02:37 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
do a search in this forum for my name, i have 3inch true duals with summit welded mufflers sittin back there, sounds mean as hell also.
Old Aug 13, 2003 | 07:52 PM
bes217's Avatar
Flowtech, I think, makes mufflers that are dual in/dual out that will fit great where the cat used to be. And they are not restrictive at all because all that happens inside the muffler is the pipes cross. There is only an x-pipe inside the mufffler. So instead of using two mufflers and an x-pipe you can just get the flowtech muffler.
Old Aug 13, 2003 | 08:02 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i'm probably going to use an exhaust setup like what willie has, except use a pair of bullets instead of the chambered mufflers like willie is doing.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 25, 2015 08:25 PM
gta power
Aug 13, 2015 06:15 AM
