hedman header opinions
Old Aug 22, 2003 | 06:21 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i was going to get slp then i found out about the denting crap, then i was gona get hooker but then i relized how much they will be with jet hot and heard about some clearance issues so now i'm goin for hedman headers and our custom exhaust shop says to get them and they already can come with ceramic coating and cost less then hooker with jet hot. so how r they and has anyone had any problems with them?
Old Aug 23, 2003 | 11:10 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
The headmans are great. Have em on my 84 TA
TA5LiterHO's Avatar
Old Aug 24, 2003 | 09:25 AM
92 z28's Avatar
i just finished putting them in and finishing my exhaust. i think they are pretty nice. fitting them into a 92 305 tbi wasnt to bad, and they seem to look and run nice. i have the elites, i recommend them.
Old Aug 24, 2003 | 05:48 PM
chio987's Avatar
Engine: 305 4bbl HO
how much were they for the headers and Y, also were the coated?
Old Aug 24, 2003 | 06:04 PM
KYL98's Avatar
Car: 1991 Z28
The headers themselves are $259 from www.Jegs.com. They dont have a Ypipe for them...but it is rumored that the standard Hedman Ypipe($99) will fit......at least thats what Ive heard. And yes they already come with some sort of coating......good luck
Old Aug 24, 2003 | 07:25 PM
chio987's Avatar
Engine: 305 4bbl HO
is the thermal coating on the Elite headers a ceramic coating. is it like let-hot coating. what's the differance between the 2?
Old Aug 24, 2003 | 07:51 PM
KYL98's Avatar
Car: 1991 Z28
That I dont know...it says they have a "thermal" coating......but you might want to email somebody at Hedman to find out exactly what kind of coating it is....I do know the headers are made out of 14gauge metal...unlike most that are 16 gauge.....
Old Aug 24, 2003 | 09:31 PM
92 z28's Avatar
its a kinda ceramic coating, from what it seems to me it looks like it will last. as for the headers them selves, they seem like a kinda "heavy duty" kinda durable type headers.
Old Aug 25, 2003 | 06:07 PM
chio987's Avatar
Engine: 305 4bbl HO
well what's the differance between the Hedman Hedders Elite Hedders coating the Hedman Hi-Tech Coated Headers coating and the jet hot coating?
Old Aug 26, 2003 | 08:29 AM
bigals87z28's Avatar
Car: Check The Sig
anyone with the elite headers wana say what they did with the y pipe? I also heard and have read that the y pipe will fit because the elite header was just a coated version of the header that is designed for the y pipe. I need to contact hedman. maybe ill call them up today. I got time. Ill report back with my answer.
Old Aug 26, 2003 | 08:54 AM
92 z28's Avatar
i had a custom y pipe made and installed. ill cost you just about the same as what hedman will charge for their y pipe, and it wont be a pain in the A$$ to install.
Old Aug 26, 2003 | 09:11 AM
Car: Check The Sig
i dunno.. last muffler shop i went to, i was charged 130 just to weld my cat back... not put together.. just weld. I can just imagine fabbing up a y pipe.
Old Aug 26, 2003 | 09:25 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If the hedman Y-pipe is still just a 2.5 inch outlet you may want to reconsider.
Old Aug 26, 2003 | 09:49 AM
92 z28's Avatar
where do you live? go to a shop tht wont rip u off
Old Aug 26, 2003 | 10:30 AM
Car: Check The Sig
hehehe yea i know.. i need to find a good shop, and not some rip off ahole midas. Ill have to venture up north jersey to find a good quality shop.
Old Aug 26, 2003 | 05:18 PM
chio987's Avatar
Engine: 305 4bbl HO
i had posted in another post that i am getting a custom cat back and includes a cacto high flow cat 3 in manderel bent stainless pipes to a 40 series flowmaster and 3 in or bigger stainless tail pipes. and it's $550 for everything. but then again i live in pittsburgh and it's a really good shop called redline
Old Aug 27, 2003 | 02:45 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
I bought the hedman headers that come with the y pipe for $328.98 from jegs and im very pleased with the performance gain i got and it is a BIG gain i got .I love it so much the y pipe is 2.5 inches but you can just cut it off and have a shop weld in a 3 inch pipe not hard at all and anyways you'll only gain like 3 hp from a 3inch y pipe that goes to the converter.
Old Aug 27, 2003 | 07:57 AM
chio987's Avatar
Engine: 305 4bbl HO
hey tbfirebird, r u talking about the collector that's 2.5 in or the pipes them self bcuz i was told by our shop that most y pipes r 2 1/4 in then go into a 2.5 or 3in collector.
Old Aug 27, 2003 | 02:47 PM
tbfirebird's Avatar
Engine: ??????????
the end of the y pip the part that welds up to the converter is 2.5 inches.
Old Aug 28, 2003 | 08:25 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
On a lo3 or small cam Lb9 you might only see 3 hp difference but when you start making more and more power the difference will start getting bigger and bigger.
Old Aug 28, 2003 | 10:07 AM
KYL98's Avatar
Car: 1991 Z28
I have the Hedman "camaro" headers...part 68491 for dual cat cars....My "header" pipes that run from the header collector to the slip insert on the Cat are 2.75" dia(inside). I measured it last nite...and they are mandrel bent. Im getting ready to put a blown 377ci in the car, so Im hoping they will flow enough.....
Old Aug 28, 2003 | 10:16 AM
Car: Check The Sig
ok.. is the hedman y pipe bigger, smaller, or same size as stock? I had a 3inch ID cat slip right over the top of my y pipe, so i would say that the y pipe is abotu 2 3/4's od, and 2 1/2 ID. Could one reuse the stock y pipe?
Old Aug 28, 2003 | 10:23 AM
KYL98's Avatar
Car: 1991 Z28
Im not sure about the single cat's Ypipe...but I know on my dual cat the pipe(s) were only 2.25" in dia I got to measuring though...and the Catco dual setup I bought from summitracing, the cats only have an inside dia of 2.25 So Ill probably need to get that replaced before the other motor goes in.... How much space did you have between the ID of your cat and the OD of the Ypipe?? The pipe itself is only .06" in thickness....so if it slide over it and there was a pretty tight clearance...Id say its 2.75" Hope that helps.....
Old Aug 28, 2003 | 10:30 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
I did'nt know hedman made a dual cat Y-pipe, that sounds like the way to go. The hedman single cat Y-pipe has a 2.5 inch outlet. The factory T-pipe has a 2.75 inch outlet on all 85-89 tpi cars and will not work with hedman headers.
Old Aug 28, 2003 | 10:37 AM
KYL98's Avatar
Car: 1991 Z28
I didnt know either till I emailed Jethot on prices for dualcat headers...and he said they had Hedmans, part 68491....Jeg's doesnt have them, neither does Summit. But they are on Hedmans website. Ill try to get a pic of them to let everybody see....The pipes are straight right before they get to the converter...so even on a single cat car, you could make dual exhaust really easy.....
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
cstrobel65
Sep 16, 2015 11:54 AM
Jlanz55
Sep 8, 2015 11:28 PM
