Exhaust manifolds
Old Aug 26, 2003 | 10:26 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
Exhaust manifolds
I think that the stock ones are not that good, but i can't switch to headers because of the law in our country.
Are there manifolds out there that fit our car and flow better?
I've seen the sanderson manifolds and the dont look like headers at the first look, so i think these would pass vehicle inspection.
Or does GM perf.parts have something good in stock?
Thanks for the help
Pat
Old Aug 26, 2003 | 04:53 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
Edelbrock T.E.S they look like headers but replace stock manifolds, they are tubualr exhaust systems
Old Aug 26, 2003 | 06:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
TES does not replace the manifolds. It replaces the exhaust up to the cat. They would be called "headers" by those who don't want you taking off the factory exhaust system.
If we're talking about the '91 TPI, you have about the best they had. You could take them off and clean/open them up a little to improve flow. I know a guy who did that and produced some respectible power with them.
The factory y-pipe is a significant restriction. If you can replace that with a mandrel-bent part, that would help performance.
Do you have a dual cat version? Those are decent as well.
Old Aug 27, 2003 | 04:41 AM
Car: '91 Z28
Engine: LB9
Yes, '91 Z28 with dual cat.
Whats different to the earlier manifolds?
Pat
Old Aug 27, 2003 | 09:58 AM
2 dope's Avatar
Engine: 305 LG4
TES does replace the manifolds, what are you talking aBout? They replace the stock factory manifolds and they have all the emissions stuff on them and they are 50 state legal in the USA. They are not headers, they are basically redesigned manifolds.
Old Aug 27, 2003 | 12:06 PM
five7kid's Avatar
Dope: They don't replace the factory manifolds because they don't hook up to the factory y-pipe. They are installed in place of manifolds,and y-pipe - true. But, they are not a bolt-in replacement for manifolds - unless you use the TES y-pipe.
However, Pat specifically said he cannot remove the manifolds because of the laws in his country. That's not the United States, in case you hadn't gathered that, so being 50-state US legal is irrelavent.
They are headers in the common use of the term on this board, and as defined in gear-head magazines, and amoung all the gear-heads with whom I associate. You're trying to narrow the defination to suit your tastes - good luck. When you get right down to it, what we call "headers" are "manifolds" in the broader defination, and vice-versa. So, let's stick to convention. And what may help the person asking the question.
Pat, back to your question: The difference between dual- and single-cat wasn't in the manifolds, but the pipe/pipes to the cat/cats. I wasn't clear on that in my earlier response. There is some improvement to be made with cleaner bends in the pipes between the manifolds and the cats. If you're limited to factory manifolds, cleaning/opening up what you have with a die grinder, and smoothly-bent pipes, is about all you'll be able to do.
Old Aug 31, 2003 | 01:30 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Would they know the difference if, maybe you switched to better factory manifolds from a different car? The manifolds shaped that were used on the 350's in the '70s were a better design than what these cars came with. They were as close to headers as you can get from the factory, but they were stock Camaro parts (as well as trucks and other cars) from the '60s to the '80s.
This is a picture of a set that looks the same, but does not have provisions for the AIR tubes. Almost any set like this that you find will have the holes for the AIR tubes, however.
Old Aug 31, 2003 | 04:28 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Corvette ram horns would be your best choice for exhaust manifolds if you're not allowed to use headers. There is also a guy out there named Brezenski that I think makes stock style looking monifolds that have very good flow. Basically all the guy makes is cheater parts for racecars.
Old Sep 1, 2003 | 05:35 PM
Air_Adam's Avatar
Actually, I just found this out the other day looking at my uncles Corvette...
His '84 Cross Fire Corvette has factory headers that have all the emitions on them.
If it just has to be a factory manifold, get those.
Old Sep 4, 2003 | 05:23 AM
Car: '91 Z28
Engine: LB9
Hey thanks all
I will check if i can get some of those! :lala:
Pat
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
