What size cutouts for SLP Headers?
Old Aug 28, 2003 | 08:39 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
It looks to me that the ypipe that came with my SLP 1 5/8" headers is about 2 1/4" in diameter. I want to put in some cutouts right before each of the cata in the dual cat setup. I see they offer 2 3/8", 2 1/2", and 3" on summit racing. I assume the 2 1/2" ones would work, just slip the y pipe inside and weld, right?
Also I need to get two new cats.The only company I see that makes direct replacement for these is random tech and they are $160 each just for the cats!!. Catco has a complete setup that included the ypipe (which I don't need for like $283. I would be cheaper to buy that setup and just not use the ypipe. The sized on the Catco setup is 2 1/4" in and 2 1/2" out, so it would weld right up to the cutouts as well. I think.
in summary, what size cutouts should I use? and who knows a good freeflowing replacement cat setup ?
thanks
Old Aug 29, 2003 | 06:58 PM
25THRSS's Avatar
as far as I know the SLP y pipe is 3 inches so you should get a 3 inch cutout.
Old Aug 29, 2003 | 07:26 PM
Car: '91 Formula
Theres no way its 3". I think they say 3" collectors, but the pipes from the collecter down to the cats appear to be 2 1/4", depending on how you measure it, but no more.
Im going to get 2 1/2" cutouts and 2 1/2" in and out cats.
Old Aug 29, 2003 | 07:27 PM
25THRSS's Avatar
Did you buy your headers used? Do they already have the turn on them that mates to the cat?
Old Aug 30, 2003 | 02:59 AM
MdFormula350's Avatar
he has the dual cat setup y-pipe which came with 2 1/4 pipes to the cat and then after the cats merges into 3 inch with the other stock "y-pipe" into the i-pipe.
yeah i would try the 2 1/2 cutouts since u cant find anything smaller.
Old Aug 30, 2003 | 03:50 PM
Car: '91 Formula
They are used/new. A guy bought them from SLP, didnt install them, then I bought them so really they are new. Yeah, they have a kind of flared end, and measuring with a ruler they look like 2 1/4". I saw 2 3/8" cutouts on summit, but Im thinking might as well go with 2 1/2". The smallest diameter in the whole system is the 2 1/4" y pipes, but there are two of course. So after the cats everything is 3" . I need to find some free flowing cats for this system. I dont want to buy the direct fit because they come with y pipes too which I dont need. Im thinking just buy two 9" carsound high flow cats and have a pipe that connects the two fabricated (2 1/2" that goes to the 3" catback. Ive heard that cutouts before the cats can give you 5 to 8 hp more. That would definitely be worth it for racing.
Old Aug 30, 2003 | 08:39 PM
25THRSS's Avatar
Oh, now I understand. You want to put 2 cutouts before the pipes merge into a y. Why dont you just put a single 3 inch cutout after they merge?
Old Aug 30, 2003 | 09:27 PM
Car: '91 Formula
If I put the cutouts before the cats, Im running without the cats, less restriction etc. I have a Borla adjustable exaust, with the largest hole plate in there, so the 3" catback is just about straight pipes anyway, hardley anything goes through the muffler. I want to bypass the cats. I hear that gives somewhere around 5 to 8 hp.
Old Aug 30, 2003 | 09:32 PM
25THRSS's Avatar
What I mean was put a single 3 inch cutout before the cat. It has been done before. Check out the guy who has a stroked 305. He did a nice job with his.
https://www.thirdgen.org/techbb2/sho...before+the+cat
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Linson
Sep 21, 2015 01:08 PM
timonator
Sep 10, 2015 07:55 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Accerrito22
Sep 5, 2015 09:34 PM
