Exhaust Components HELP NEEDED
Old Aug 29, 2003 | 06:44 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
My stock exhaust system bite the dust- I just got it totally removed along with the plugged catalaytic converter. I just scored a set of shorty style headers from a friend. I have just got the Flomaster 80 Series muffler for a great price. So now I need to know the following:
1. Is there a y-pipe that I can get that will fit these headers- I was told that they are the same length as the stock manifolds. I got pictures if you want them.
2. Are the stock exhaust ports on the 1991 LO3 round or square? So I know which gaskets to get.
3. Where can I get a intermideate pipe from where the cat is supposto be to the muffler. Can you make a off-road pipe out of a piece of regular 3" pipe? Or do you have to buy some special pipe?
Thanks a lot
Old Aug 30, 2003 | 09:50 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
First off we need to know what brand headers they are. Most companies make y-pipes for their headers and they don't usually work with other manufactuer's headers. The exhast ports are square, I would reccomend a good set of Earl's dead soft aluminum gaskets along with a set of stage 8 header bolts. With those you'll never have to tighten the headers back down. Dynomax sells and i-pipe that goes from the cat to the muffler, it's 3". I don't know the part number but do a search for it and you should come across it fairly easily.
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
