No headers for my application. :(
Old Aug 30, 2003 | 12:24 AM
jharms's Avatar
I dropped in a 455 Oldsmobile in my '86 Firebird and am in need of some headers for my motor. The whole time I have had to improvise, overcome, adapt: AKA spend alot more money, just to make this work but I fear the headers will be my doom. I finally dropped the motor in my car, got the tranny bolted up, and am now on a search, a very frustrating search, for headers. I know they don't make headers specifically for my application but I was wondering if headers for a '77-'87 Cutlass with a 455 Olds. would work? The G-bodies aren't that much larger, if any, than our F-bodies so wouldn't the clearances be close enough to install the headers in my car? Hooker makes some for that engine swap, they're PRICEY!!!! BUT they're still probably cheaper than custom headers. What is your opinion on the matter? Any advice/help would be MUCH appreciated.
John
Old Aug 30, 2003 | 01:46 AM
85Z28's Avatar
Car: 85z28 // 97 Hawk
Engine: wore out 360 // LT1
Transmission: 700R4 // 4L60E
Axle/Gears: 3.73 // 3.23
I'm pretty sure that I have G body headers on my car. I don't know for sure because my dad had these headers laying around. they fit but needed alittle bending to keep from knocking the floor. Mine are also small block so I don't know how well ones for a 455 would fit.
hope thats helps alittle.
Old Aug 30, 2003 | 09:11 AM
jharms's Avatar
That's a start, thank you. The thing is I don't want to have to bend the headers, as if anyone does, but particularly with mine because I want to get the ceramic coated ones and if I have to weld on them, then it ruins the coating. Of course I could always get the uncoated, which are a $500 and then do what I need to them and then have them sent off to get coated.... Or should I be considering custom headers?
Old Aug 30, 2003 | 10:07 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
you could always buy to build a kit headers and build them yourself to fit.
Old Aug 30, 2003 | 01:33 PM
jharms's Avatar
I personally couldn't do it. I don't have enough experience with a welder, it would turn out awful and probably wouldn't even be useable.
Old Aug 30, 2003 | 09:41 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I would just get the headers from hooker. They may be exspensive, but they should bolt right up without any fuss. Worth it to me...
Old Aug 31, 2003 | 12:14 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
a 455 in a t/a that rules man :rockon: , good luck with the headers and I hope I dont get lined up next to you at a light
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Chad Speier
Sep 24, 2015 12:32 PM
