Header Leak...ahhh
Old Aug 31, 2003 | 07:47 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Header Leak...ahhh
Ok heres the situation..My car was wrecked so the frame has a little wrinkle in it. My driver side headers set it and pulled up fine. The passenger side wouldnt even fit, We beat the frame to where it looked like everything was good to go but the flange was hitting a little, But everything looked like it lined up. We tighetened everything and got all my new exhaust put on. Now I got a bad leak on the passenger side and the gasket looks burnt. Its leaking out the top of each port... I've tightened it twice but I think It was too late and torched the gasket. So do you think the flange is not letting it pull up tight enough and I am not gonna get it to stop leaking without fixing that? Could I double up the header gaskets and get it to work? Or just replace the gasket and tighten the hell out of it? I got my new motor and everything ready and this is my last bug to get out!
Old Sep 5, 2003 | 05:49 AM
SLOWFIVEOH's Avatar
Engine: 355
THANKS!!!!!!!!!!!!!!!!!!
Found a temporary solution
Old Sep 7, 2003 | 11:30 AM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
well DONT tighten the hell out of the bolts you will warp the flanges. try putting better gaskets in and see what happens.
Old Sep 7, 2003 | 11:33 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
ouch that hurts. i am not your friend no more. if ya tighten the collector bolts too tight it might warp the flange and then it wont seal very well.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
