White Smoke???
Old Sep 14, 2003 | 11:21 PM
IroczCamar0's Avatar
Car: 1989 Pontiac Trans AM GTA
White Smoke???
My friend has a 1986 iroc 305 tpi, and when he starts it up white smoke comes out of the tailpipes, its not blue at all. What could be causing this to happen??
Old Sep 15, 2003 | 12:37 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Possible blown head gasket. Does it continue to smoke, even if not a lot? White smoke usually means water is in the combustion chamber. Another thing is how cold is it outside when he starts it? Could just be condensation.
Old Sep 15, 2003 | 02:06 PM
Yea when it firsts starts up alot comes out and then after its running its tilll comes out a little and only when u rev it up it will come out a little more.
Old Sep 15, 2003 | 02:43 PM
It comes out everytime he starts it regardless of temp it has come out...sorry forgot to say that
Old Sep 15, 2003 | 06:57 PM
trans87's Avatar
Sounds like a blown head gasket. Check his oil does it look milky or muddy? Is his car consuming coolant?
Old Sep 16, 2003 | 12:24 AM
Drop Top Iroc's Avatar
Car: 88 iroc Z28 Conv
Engine: stock 305 for now
Transmission: new 700r4
i have a 88 iroc it happens to me as well its really just old piston seals yur gettin some oil in those cylinders and when it starts to burn it smokes
Old Sep 16, 2003 | 12:58 AM
trans87's Avatar
Oil burns blue though not pure white. Plus the white smoke he said continues to come out even after start up.
Old Sep 16, 2003 | 01:29 AM
bigals87z28's Avatar
Car: Check The Sig
check the oil for what will look like a very very chocolate milk looking oil. this does not look good for homestar runner....
Old Sep 16, 2003 | 10:18 PM
Cali Z's Avatar
what else could be burning off besides oil?
Old Sep 16, 2003 | 11:50 PM
trans87's Avatar
Coolant/water.
Old Sep 24, 2003 | 04:24 PM
Redline's Avatar
Car: 88 camaro SC
Engine: 305 t.oilet b.owl i.njection
Transmission: rebuilt 700r4
doesnt oil burn 2 different colors, depending on whether it came in contact with the actual flame, or just a hot part?
im not sure if its white, its been a while, then blue as the other
i learned about this with turbos--its a way of finding out where the oil leak is coming from
Old Sep 25, 2003 | 01:04 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
No, it's coolant not oil! Soon enough there will be more white smoke and the eng. temp. will go right up to 250+ after running for only 5 minutes. Then you'll know for sure that the head is either coming off or you'll risk cracking it in two, not to mention the possibility of ruining other engine parts.
Old Sep 25, 2003 | 03:20 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
its a blown head gasket, u may want to stop running untill u get that fixed before u crack a head.. i made that mistake and it was very expensive, but gave me a reason to build a brand new motor
Old Sep 25, 2003 | 04:25 PM
Thanks for the replys, its not my car, its my friends and i told him it could be that but he seems to think it is nothing and he is goin to contiune to drive it, he doesnt know anything about cars so i dont know why he will keep usin it but, i guess he stop when he eventually cracks a head
Old Oct 1, 2003 | 03:01 AM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
I have the same problem...a lot of white smoke comes out when I crank it (everytime) and a little comes out when I give it gas, but my oil is not milky, and it doesn't burn any oil either.....could I have a Blown head gasket? Or is my valve seals leaking?
Old Oct 2, 2003 | 02:45 PM
SX Stinger's Avatar
Car: 84 Z28 "Holly" (SOLD)
Engine: Carbed 305
Transmission: TH350
Yeah wj\hile we are on the topic, Sometimes if I give my car gas as i am starting it white smoke will come out, But that is the only time. It is also if it has been sitting( while im at work or over night). There is no water in my oil, engine is relatively new and the heads were checked. Is it just condensation??
Drew
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
