Cat. question...
Old Sep 29, 2003 | 11:41 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Cat. question...
Ok i have a '86 T/A with a 350 TPI w/ the mods in the sig. My question is, would i be better off with a high flow cat or a hollowed out one? Right now i have a high flow. If i hollow it out what would the difference be?
Thanks in advance.
Old Sep 30, 2003 | 01:05 AM
25THRSS's Avatar
either don't touch it or put a straight pipe through it
Old Sep 30, 2003 | 05:41 AM
cunawarit's Avatar
Car: 1990 IROC-Z daily driver
Engine: 305TPI
Transmission: Automatic
I wouldn't touch it, if you have a high-flow cat that is working properly the improvement will most likely be minimal.
I run no cat and I noticed a big improvement because my original cat was old and partially blocked, however, even though the car passes British emission tests it does smell now and it didn’t before... Ideally I’d have a high flow cat.
Old Sep 30, 2003 | 05:07 PM
Well i have to have a catalytic converter so i cant just remove it and run straight pipes. I heard if you hollow out the converter that it will make your car a little louder? I wouldn't mind my car being a bit louder but not too loud.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
happyhapka
Aug 15, 2015 04:42 PM
KlayBuRn
Car Audio
Aug 30, 2001 12:52 AM
Lotsokids
Carburetors
May 28, 2001 08:42 PM
