Exhaust for 82 Trans Am ?'s
Hello, I need to replace the exhaust on my 82 TA. It currently has it's orginal exhaust. I have searched and no one seems to offer a system for 82.... 83 up seems to be avalible everywhere.
The one and only option I have found (aside from custom work) is a system that is suppose to fit 82 untill 87 I think it was. It only has one muffler where as the stock set up has two.
What have others with 82's done or recommend doing?
I heard it's not possible to have a true dual set up, is this true?
If I were to order the aftermarket system for 82-87 TA's, is there a coating I could put on it? Where could I have something like that done?
Thanks in advance, Steve
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I am also curious to know because I have an 83 Z and I have the same stock setup as you. The one with two mufflers.
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Car: 83 Z-28
Engine: LG4
Actually I do have 2 mufflers. Here is a diagram pic of what it looks like. Tommorow I will post some pics of mine.
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I have an 82 T/A that had the same 82 only exhaust set up. I recently had my cat removed, part of my Y pipe, and put in a new stainless steel high flow muffler. It was all custom done.
Based on research I have done on this board, the 82 uses the same hangers as other years for the exhaust system, so you can choose a post 82 cat back system. It's just that companies don't list a system that is a DIRECT replacement for the 82 system (with two mufflers and two outlets).
I always hear we should choose the system designed for the 350 TPI as it is the most free flowing. 87 to 89 I think?
Car: 83 ta
do not know if it is true or not but I have read some place that the factory setup is not to bad. Free flow stainless steel system with a cat. I have a 83 TA with the dual muffler set up. anyone checked the price of replacement of the system? just curious what to expect when the times come.
Transmission: 4L80E/4L80E
Unless you've got some dreams of keeping this a factory-like restoration, your best bet is to toss the entire system.
The aforementioned (if not quite accurately) '86-'90 TPI single-cat system is the best aftermarket system out there. If you start with headers, like the Hooker 2055, a high flow cat like the Catco 9118, and a cat-back like the Hooker 16823, it will all basically bolt in there (minor hanger and A.I.R. modification may be necessary), and perform much, much better than any factory-type 2-muffler system.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
