True dual exhaust idea w/o tips
Old Oct 4, 2003 | 02:38 AM
joshwilson3's Avatar
Old Oct 4, 2003 | 05:56 PM
stupid4901's Avatar
Well if u have the exhaust dump under ure car, ure gonna feel the rumble and get fumes in it. Fumes can cause lots of problems, if u have the exhaust dump out to either side then u should be good.
Old Oct 8, 2003 | 10:59 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You might not have enough space for two mufflers where you are wanting to put them... There's not a lot of space down there...
Old Oct 8, 2003 | 11:18 AM
darbleinad's Avatar
Car: 84 Trans Am
those arent true duals...true duals = pipes are the same length
but that is still dual exhaust....make sure you use 2.5" pipe and might as well put a h-pipe in there.....some dynomax bullet mufflers would probably work best in this situation. it will be loud, but for some people like me, that isnt an issue
Old Oct 8, 2003 | 12:56 PM
StumpPuller's Avatar
not to mention the fact that not having any tips will make the police wish to have a word with you. granted you have an exhaust system, but they won't know that and will want to question you about the apparent lack of an exhaust system.
Old Oct 8, 2003 | 01:01 PM
Old Oct 8, 2003 | 05:58 PM
darbleinad's Avatar
Car: 84 Trans Am
technically a true dual exhaust system has both pipes the same length. ie the exhaust pipe coming off the drivers side header is the same length (give or take a few inches) as the pipe coming off the passenger side header. you system is not like that, so you simply have dual exhaust. true duals would be better, but there is nothing really that wrong with your system. it is similar to the factory exhaust, except there is no y-pipe and as a result, it uses to mufflers.
i have a true dual setup on my car. i have longtube headers that dump into 2.5" pipe. there is an h-pipe between the 2 pipes. the 2 pipes are the same length.
Old Oct 9, 2003 | 04:49 AM
allboutspeed's Avatar
Car: '87 IROC Z-28
Engine: Horse **** 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 posi
Design looks doable, however you will run into clearance issues with the tranny cross-member when you bring the driver side pipe across to the passenger side. There is enough room to mount Dyno max bullets right on to the reducers, then all you need to do is run pipe out to each side where ever you think it looks the best(in front of rear tires works good).
Old Oct 9, 2003 | 10:57 AM
jasonbennett's Avatar
why don't you just do a nascar style exhaust with spintech mufflers
Old Oct 9, 2003 | 11:51 AM
learsieglerZ'83's Avatar
Car: 1983 Z28
Transmission: 5 speed
your drawing is awesome!!! what kind of wheels are those???
Old Oct 9, 2003 | 04:53 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
True dual exhaust refers to the fact that the exhaust never Y's at any point (excluding an X pipe). It is a term people use because a lot of people think that dual outlets on a muffler = dual exhaust.
It would be ideal for the exhaust to be the same length, but if you put an X or H pipe in that should balance out the exhaust.
Old Oct 10, 2003 | 11:42 AM
nolanr0413's Avatar
Car: Trans am
fume problems if it exits under the car , i dont think so , i dont know if you guys sit in your cars and try to get high or something but my dad has a trans am with duals and it dumps right before the rear alxe and their is no problem with fumes. he's had this set up for years and no problems, maybe if you sit in your car and play with yourself and try to get high on fumes , but otherwise thiers no problems.
Old Oct 10, 2003 | 09:15 PM
89TurboV6's Avatar
LMAO
Old Oct 13, 2003 | 09:54 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
