3/4 or 5/8?
Car: 1992 z28
Engine: 5.7
Transmission: auto
3/4 or 5/8?
I am trying to decide what to get the 3/4 or 5/8 headers. Both are nice but what will i get out of them? Power, sound, what are the pros and cons?
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Both will do you just fine. The one thing you have to ask yourself, though, is what do you have planned for the car. If your not planning on doing anything more than 400 or so ponies, i'd say go with the 5/8. If you plan on going higher, go with the 3/4's.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
1 3/4s are usually for highly modded 350's, 1 5/8s would probably be enough. Kinda like a TB, 48mm (stock) are good for alot of power, when your're really up there that's when you wanna get a 52mm or 58mm depending. You do not list your car or plans though. So, it's really difficult to tell.
Originally posted by Camaro_nut
What if you plan on getting about 350 hp and 400 ft. lbs.
at the flywheel?
Is 1 3/4" headers still overkill??
at the flywheel?
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
With an N/A 350 thats not shifting over like 6200-6500RPM you'll be great with 1 5/8" headers even if you're making a good amount of power
roysatikas
Sep 22, 2015 08:15 PM
86White_T/A305
Sep 21, 2015 05:28 PM
