Can a clogged cat cause a lean condition?
Old Oct 14, 2003 | 12:36 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Eversince my cats started making noise, my car has been running like s**t. I pulled my plugs and they were all white.
White=lean no?
Old Oct 16, 2003 | 03:43 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I dunno about making it run lean, but it could be stocking up ALOT of heat in the pipes and manifolds before the cat.
If you gutted the cat, that could make it run lean because of less back pressure to reverse the unburned fuel
Old Oct 25, 2003 | 11:28 PM
[superbird]
Guest
Posts: n/a
if lean is bad gas milage then yes
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
Stryker412
Sep 7, 2015 09:11 AM
Jetmeck
Sep 4, 2015 12:29 AM
