header types
Old Oct 15, 2003 | 10:45 PM
tataconka's Avatar
Car: 1992 z28
Engine: 5.7
Transmission: auto
header types
There are different types of headers and i would like to know what they do. For instent, shorties? what type of performance do u get out of them. competition? super comp?street rod?tubular?block hugger?afterburner? I dont know what they are our how they work. Please help me on this...Thanks
Old Oct 15, 2003 | 11:13 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
I think the only ones for thirdgens are long tube and shorty. Shorty is just a manifold design that has been enhanced. It is rather short but it has seperate tubes for each exhuast chamber which allows for better flow and less turbulance from the head but they have short runners(hence the name) and don't allow for a long range of unrescricted flow. Long tubes are about the same, 1 tube for each exhaust chamber, but they are extended all the way under the car to allow for a long range of flow and more velocity, and less restriction. Long tubes will give a higher performance gain over shorties but shorties are easier to install. That is about the extent of my knowledge on headers..hope this helped some.
Lc
Old Oct 16, 2003 | 05:10 PM
tataconka's Avatar
Car: 1992 z28
Engine: 5.7
Transmission: auto
I want something with a nice sound to it. It sounds like the long tupes would be better for that, is that true? Which ones give you more power?
Old Oct 16, 2003 | 10:36 PM
305RSlc's Avatar
longtubes
Old Oct 16, 2003 | 10:44 PM
biff85ta's Avatar
Car: 04 Vette
Lontubes are definately the way to go if you din`t have to worry about emmisions.
Old Oct 17, 2003 | 10:48 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
Actually if you talk to a tech at holley they tell you not to run longtubes on street driven cars because it looses to much ground clearance.. that's what made me decide on the 2460's instead of longtubes.
Old Oct 17, 2003 | 01:14 PM
biff85ta's Avatar
Car: 04 Vette
I still have plenty of ground clearance with my lt`s.
Old Oct 17, 2003 | 07:14 PM
tataconka's Avatar
Car: 1992 z28
Engine: 5.7
Transmission: auto
what type of emission problems do u run into? Is there a way to get ride of the problem?
Old Oct 18, 2003 | 02:45 AM
biff85ta's Avatar
Car: 04 Vette
Well it is hard to pass a visual with lt's and I have no cats at all with my setup.
Old Oct 18, 2003 | 07:43 AM
305RSlc's Avatar
What's a CAT.... ....gotta love Florida
Lt's won't take away ground clearance anymore than a poorly hung exhaust, they are definitely the way to go.
Old Oct 18, 2003 | 08:10 AM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Just take it easy with the car and you shouldn't have any problems with ground clearance.. Avoid speed bumps religiously, and don't go off-roading.. That includes grass!
Old Oct 18, 2003 | 09:38 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Hedman Longtubes don't hurt ground clearance at all. If you run the exhaust right you shouldn't have a problem. I'm thinking about running them again. Not sure yet.
I had longtubes, true duals, no cats...omg hedman LT's, h pipe, and 2 chambers flows is LOUD
Twin_Turbo
Mar 14, 2016 10:10 PM
Chad Speier
Sep 24, 2015 12:32 PM
Hello, Michael
Sep 11, 2015 01:10 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
