Hooker 2460 Install
Car: 89 Formula
Engine: 305 TBI
Hooker 2460 Install
Hi All just ordered a set of Hooker 2460s from Jet-Hot. going to be installing headers for the first time on my 89 formula 305 tbi already have AIR removed. what reccomendations you guys got. i also will be ordering a banks or slp catback and ordered a carsound cat. would you guys reccomend i put in a cut out??? please give all comments and suggestions
Transmission: 4L80E/4L80E
Do you have any kind of emissions testing? The cat will work better with a functioning A.I.R. system.
I hope you realize you're going to have to have a y-pipe fabricated, or your current one modified. The factory pipe won't connect to the headers outlets.
I'd recommend 2-1/2" down-pipes joined with a 3" pipe going to the cat, a 3" TPI-type direct-fit cat & cat-back. This will support you well into any mods you can make to an LO3 engine.
Car: 89 Formula
Engine: 305 TBI
as long as i have a cat i can get my mechanic to pass the car. i ordered a car sound 3 " slip fit cat. and plan on haveing an ss y pipe fabricated.
I was thinking about something like this... you can try it out. Its basicly a 4 bolt flange mounted on both sides of the cat, and then a matching flange for teh y pipe and I pipe... then you can unbolt the cat whenever and bolt in the cut out.
(dont knock the MSpaint skills.. you know you love it!)
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Doesn't NY use california emissions now?? I know mass does.
Anyway, I researched the 2460 y-pipe deal. It's gonna be a bunch of 45's basicly, and then a 90, and 45 after teh y-collector.
I did a post on all the parts needed to make it up.. Modifying a SS y-pipe would be a bad idea..
The 2460 is a decent header, but because of the thicker gauge material it makes it not much larger than the Flowtech's.. And with the Jet-hot you just added .010 to it's ID (the recommended tickness of ceramic coating) ..
-- Joe
-- Joe
ambainb
Apr 25, 2016 09:21 PM
:lala: :lala:
