Heated 02 sensor
Old Nov 20, 2003 | 04:09 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Heated 02 sensor
Just finished my exhaust upgrade:
jet hot coated slp 1 3/4" headers
dual 2 1/2" converters
3" intermediate and over-axle pipes
flowmaster 3" in, dual 2 1/2" out muffler.
As I feared, it's not running right. I've read of others on this board who had the same problem .. their exhaust was too "free flowing" and the o2 sensor no longer worked properly.
I believe this is caused by the exhaust gasses flowing past the sensor so fast it doesn't get enough heat.
I want to go to a heated o2 sensor to correct the problem.
what brand/part number would be the best heated (3-wire) oxygen sensor? Where do the additional wires hook up? simple power and ground?
Old Nov 20, 2003 | 10:38 PM
breathment's Avatar
most O2 sensors are all the same (when talking about non wideband sensors). especialy when dealing only with all 4 wire sensors, or all 3 wire sensors. The main difference between the sensors are the wire lengths and connector. Just about any sensor u can get yours hands on will work, they all fit the same size and send the same information. You can get a universal O2 sensor for about $50 at autozone. I got mine from GMPartsdirect.com for like $60 i think. Dont' remember the number but ill try to find it.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
