header leak?
Old Nov 18, 2003 | 07:58 PM
88IrocTPI's Avatar
Car: 88 Iroc
header leak?
hey guys,
I think i have a header leak, i cant really pin point it under the hood but when im driving, it sounds like light tapping coming through my dash and when i pop the hood i can also hear the tapping. It is not valves or lifters!! thanx does this sound like a header leak to u guys
Old Nov 19, 2003 | 06:39 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yes..
Old Nov 20, 2003 | 11:31 PM
RedGTAWSU's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: L98 350
If it's leaking at the flange you can probably feel it if you put your hand near the top of the flange while the car is running. I have the hedman longtubes, and I'm having a flange leak problem on the driver side. I've put my hand down there, and even when there isn't too much pinging, you can feel it. So, CAREFULLY, put your hand near the flange above each primary and feel if there is any air coming out. The air will be comin out at a noticeable rate if it is leaking loud enough to make noise.
Ryan
z 28 jari
Sep 14, 2021 10:03 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
