Are the flowmaster 80 series mufflers the same size internally?
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Fits in the stock location..They list two part numbers a 42583 this has a 2.5" inlet with two 2.5" outlets. And a 43083 that has a 3" inlet with two 2.5" outlets. The case size is the same for each.
I want the 3" but..I might buy a used one for cheap that has the 2.5" inlet. What IM wondering is.. if they are the same size internally? I dont want to choke my exhaust if its retrictive. I have a 3" dynomax system now with the two on the left pipes. I want to install a set of 4thgen tips. Thats why IM changing the muffler.
I could open the end of the muffler to 3" and just weld my 3" pipe to the muffler. This would be easy.
But..what im wondering are the openings inside the chambers the same for the 3" and the 2.5" inlet. And they just changed the inlet to fit the application.
Cant be that simple right?
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
As far as i know they are the same size internally, its just the pipe size thats different, someone else maybe able to tell you for sure tho.
Kevin
Kevin
Car: 90 IROC
Engine: 406
Well I just got off the phone with Flowmaster. They tech guy said that they are indeed the same internally. The holes between the chambers are the same size. Same muffler...Just a different size inlet.
They way the muffler is designed it would be easy to open the inlet to fit my 3" pipe.
Just wanted to let anyone who might be interested know.
Thanks Deepstage69 for the reply.
Mike
Mike
Engine: 383, L69
No prob man, i was wanting to know also since mine is 2 1/2, and i was wanting to make it 3. thanks
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
so if you were going to use the stock I-pipe( as in my case), I would want to get the 2 1/2 inch inlet instead correct?
Thanks.
Brandon
Thanks.
Brandon
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
