Who's running 14's with Dynomax cat-back?
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
If you run the 1/4 mile in less than 15.0 seconds and are using the Dynomax/Walker SuperTurbo cat back please tell me what times you ran. I would also like to know what type of induction system you were using, so I can try to determine the limitations of this exhaust system. Thanks
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
My friend Joe (SLP IROC-Z) ran a 13.9 @ 97mph with his Dynomax catback. This spring he started running 100mph traps but had no traction off the start.
He has a stock TPI setup with a ported plenum.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My best 1/4 so far with the IROC is a 14.3@97, and I'm still using the 2.5" dynomax Super Turbo catback.
I even have a sound clip.
http://www.sover.net/~iroc85/85_iroc_exhaust.mov
The car should be much faster, but that's a whole 'nuther story.
cool, thanks for the sound clip. The car this will be going on is a 305 with about 220hp, I think both of you have 350's. I read in another post that "a" super turbo free flowed up to 175hp, but I know it was not the part number used for our cars, so it might have been smaller or whatever. Anybody else have times?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I had the 2¾" system on my Camaro with an LG4 and had hit 14.494 and 98.69 with it.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
