Custom exhaust routing
Old Nov 29, 2003 | 01:17 AM
Stokdd's Avatar
Car: Yellow '92 Formula
Transmission: A4
Prolly gonna get a custom exhaust built after xmas ($$$) but I'm not sure how I want to route it. Exhaust on their now goes down under the passenger door sill then back to the middle, into a single tube, then spits at the tips. Not to most efficient, if you ask me. Plus the flowmasters aren't loud enough .
Anway, I was thinking maybe dumping it behind the front wheels, with some shorty mufflers after the cats. Or if that won't work, maybe dumping it in front of the rear wheels. I wanna do something somewhat original that'll still sound good. Any opinions? Pictures would be much appreciated, too.
Old Nov 29, 2003 | 11:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You have the stock routing, which was answered in your previous thread. Yours may be sagging down a little more than typical, that's all.
There's nothing "original" about what you propose. See stickie at the top of this forum: https://www.thirdgen.org/techbb2/sho...hreadid=204351
Without exception, such systems will compromise at least one (if not all) of the following: Ground clearance; passenger compartment resonance; keeping fumes out of the passenger compartment; appearance (I'd say "ghetto", but that isn't nice...).
On an otherwise stock TPI car, they would also be a waste of performance money. A properly chosen and installed set of aftermarket products, routed as-factory, will maintain ground clearance, keep interior noise to a minimum, route fumes away from the passenger compartment, look good, sound nice, and support performance well beyond what a TPI system can produce.
Old Nov 29, 2003 | 01:02 PM
Stokdd's Avatar
Transmission: A4
I mean original as I haven't ever seen a 3rd gen with side-exit pipes. Didn't go to that link because I'm in a hurry, but I have no doubt it's been done before.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
