o2 sensor in manifold, how do you get the drivers side manifold off?
I have two questions
1.Would it hurt anything if i didnt put the sensor that is in the drivers side manifold back in? My headers dont have a spot to put it so i will have to drill a hole.
2. Also, how do you remove the drivers side manifold? I'm having trouble taking the first bolt off. I have removed the AC, and was wondering if you need to remove the power steering bracket also. Thanks for any help
Transmission: 4L80E/4L80E
Re: o2 sensor in manifold, how do you get the drivers side manifold off?
But, other than that, wouldn't hurt anything...
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
To get the manifold off just like, un-bolt it
You may have to lift the engine up slightly to get it out, I put headers on my friends 88 with the motor in the car, no lifting required. Shouldn't be too hard, just unbolt it from the head, undo the AIR(if so equipped) and unbolt the flange from underneath(may be hard since these have a habit of rusting, just use wd-40, and maybe heat it up) I ended up cutting it with a sawzall. Hope this helps. Peace.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
transaero
Aug 31, 2015 01:14 AM
