Can i run my engine w/o A.I.R. system?
Car: 1992 Firebird
Engine: LO3 305
Transmission: 5 speed
Axle/Gears: 3.08 limited slip
Re: Can i run my engine w/o A.I.R. system?
ive been through this thread and read and skimmed some parts. i have a 92 bird with the TBI 305. i want to do this but ive heard that the maifold threads are 3/8 and ive heard they are 1/4. which is it? also im broke and cant weld so what is the best/cheapest way to plug the tube going to the cat? i read just pinch it with vice grips?? really? im more of a visual guy so any pics to go along with a description would be awesome!
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
And for the hole to the cat, yea, bend it, except it's probably really hard to bend because mine was super thick for some reason. Might have to use a torch to heat it up a bit first. I drove around for a few days with it open before I just straight-piped my cat. It's just extra stinky when driving.
Car: 1992 Firebird
Engine: LO3 305
thanks for your input. i like it when people try to help instead of slamming you for doing something.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
for the cat couldnt you just take the cat and slap some flanges on it? i took a 3 inch dynomax cat, banged the oval part round, welded 2 tri-flanges on there and made a secondary flanged 3 inch pipe so i can just remove the cat and put in the "test pipe" lol
My AIR system is almost gone. I did notice after removing it that I smelled more crap than ever before. Hold up, maybe that was my own gas or maybe a smelly truck I passed? Oh well.
Car: 92 camaro 25th anniversery
Engine: 350 TBI
Transmission: 700 R4
Axle/Gears: 3.73 9 bolt
Has Anyone from delaware on here took their Air pump off and passed the delaware emmissions tests? I just took all mine off and installed hooker 2460s and have to go through the delaware tests in october.
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Hey Guys,
My name is Fermin and I wanted to ask a question about the A.I.R System being pulled out. Last friday i went to a mechanic that was going to install my headers well he didnt want to do it becuase of the A.I.R system. I told him to delete becuase i dont want it anymore as im running LT headers with no cats straight to my Borla Exhuast. Well i want to double check is there a way to install these headers easier then doing the whole deleting of the pulley and all that. Can i just plug the lines somewhere. Please help me as when i take it to the mechanic i wanna be able to tell them this. 1992 Camaro 5.7L L98 TPI...Also i know its been talked if you loose Hp on a 305 how about my 350?? Please help thanks
Car: 85 marrow z28, 88 thunderbird 5.0
Engine: 305 4bbl, 302 cobra efi
Transmission: 700r4, aod
Axle/Gears: the crappy one
Seems all of these posts are mostly relevant to tpi/tbi setups. I just started this on my 4bbl 305 yesterday. There are a ton of vacuum hoses going from the carb to the various a.i.r components, do I just block these off?
-Blain
-Blain
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
does anyone have a size for the plug bolts that thread into the stock exhaust manifolds in place of the air tubes on an 88 350TPI in the IROC-Z. i see that classic industries have them, but i've got a shop full of pipe plugs and bolts so i might already have them laying around.
Car: 1987 Trans Am
Engine: 5.0 Liter
Hi guys,
I've been grappling with the same issues on removing the emissions, smog stuff because I couldn't get to my spark plugs. I believe in clean air, but I also believe in a clean burning engine that doesn't smell. Personally, I think that's the most logical way to look at this. I mean if, you're burning up all the gas going into the chamber, what's left to pollute anything? Not exactly a scientific approach, but it makes sense to me. When ever one of those big jets take off at the airport, I think they put a whole lot more stuff into the atmosphere than one car can do in a lot of tries....
I just got through pulling off the tubes from my 87 305 and was able to change my plugs. I hack sawed a couple on the passenger side and just unscrewed the lines on the drivers side. I'm not a mechanic though and don't know exactly what to do with the two tubes coming up from the back of the engine. They suck air, and what do I need to do with them?? I've spent about 4 or 5 hours reading your conversations trying to figure it out and no one has really stated what we need to do with them. I think they must need some kind of filter on the end. It seems like they need to breath...
Dale
Dale
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Jets are aproved by the FAA to fly, they emit polutants but its approved, and our emissions equiptment is required by federal law technically, its out dated but still considered a requriement. I'm not preaching here just puttin it out there
And what one the smog equiptment stopped you from changing plugs?! Try putting in some headers and doing the plugs, then get back to us and tell us your solution, I don't think you'll take a hacksaw to. Do them, I hope not atleast.
Some plugs come from the top some from the bottom, you just gotta try different angles and positions to see what works best
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
When I took off the AIR on mine I had bloody knuckles from all the BS.That snowballed into modified exaust and eventually a decision for an engine swap which I'm still doing now.To the original question..It didn't effect the way my engine ran at all.I plugged the holes in the manifolds with 1/2 inch bots and called it a day.I eventually pulled the ecu and all related wiring and behold!!!. It still ran.Now I have all mechanical gauges and I love it.No more electronic crap to foil my senses.I love a V8 with nothing but a spark,gas,oil and coolant.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Is there a definitive answer as to whether you can run a high flowing CAT without AIR injection? After reading all 6 pages I have not yet really seen the answer to this question. My PROM is tuned to accommodate the removal of AIR, so no issues there.
As I understand it, AIR warms up the O2 sensor until it is active (not needed in my case as I run a 3 wire heated O2 sensor) and then breaks up the carbon monoxide in the catalytic converter (in closed loop, once O2 is warmed up) which further reduces emissions.
I have no AIR injection plus a gutted cat, but I want to buy a non-AIR high flow cat to reduce emissions and keep the AIR system removed (i don't have to test for emissions, I want to install the cat just so that the air around me is better the breathe).
Can I run a high flow cat without air injection?
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
So you just put caps over the metal tubes that the air hoses were attached to? Where did you buy these caps if there special caps for it or w/e lol. I just put headers on mine and have to do this.
Car: 88 Iroc-Z Convertible
Just got done pulling my seized AIR pump off my car. Went with the Belt routing in the Middle picture of the Tech article (Which is basically my factory routing on my 88) and a Duralast 968K6 Belt. (96.8" belt = 2460mm Belt for those of you that dont have a US to Metric converter handy. Some manufacturers part number will show mm instead of Inches)
For reference, the Pump is attached to the Bracket via 2 long bolts that can be removed from the front of the pump. Above and Below the pump. These 2 bolts are T45 Star Drive(Torx).
As for the Catalytic converter needing the O2 Pump, It doesn't really, but having it will reduce you emissions more... Mostly when the car is cold. The oxygen being pumped into the manifold helps burn off gas and heat the Cat up quicker. The Air going directly into the Cat also helps mostly when the car is warming up as well. Once the car get to its operating temperature, the air isnt needed. I think most Gm vehicles actually went to an electric pump that only ran during open loop/cold startup in the early 90's and today, there is no air pump at all.
This pretty much answers my question! Thank you. The car is slightly quieter inside the cabin and much less smelly so installing the cat was a great idea just wanted to make sure everything was done properly.
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Axle/Gears: 3-73
The y pipe is it the same for the 2 styles of exhaust manifolds
My car has the 305 with the injector tubes. where as the 350 doesnt have any exhaust injector tubes will the same y pipe work on both applications
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
All Thirdgens has injector tubes. Yours was probably removed
my 86 stock carbed iroc- is hurtin for power: can I just remove the air pump belt? the AIR system takes power to run it, so any gain(in better emissions) from this system must be thrown off by the amount of power (gas burned carbon output) to run it. or so it seems....that the system is pointless.
My guess is that if this system worked, it would be on new cars. Ive never seen this system on any other car.
Anyway, my question is if I remove the belt- will it clog up the lines with crankcase fumes? I think they just go to the cat and exhaust manifolds, but im not sure. This motor has 160k on it and it smokes a little
there are so many replies on this, if its posted and I missed it maybe you could direct me to it. thanks
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
In regards to the delete pulley, what happens if you disconnect/cap off everything, and leave the AIR pump in there? I've seen mixed results of doing this, some say it's fine, others talk about it seizing up. I'd prefer to just leave it in there instead of getting a new belt or a delete pulley.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
For those of you saying our cars will run rich without a.i.r. clearly have never done it, I took mine off and it runs sooo much better now and isn't lean at all, the exhaust actually stinks less now as well.
IIRC (it's been awhile) The reason for running lean (I don't think it runs rich?) is that the O2 sensor sees that there is "less" O2 in the mixture, it therefore reduces the fuel to accommodate. If you adjust the PROM then it will fix the problem (although I'm sure it's hardly noticeable).
Maybe your AIR pump was seized and that's why it runs better? In any case, as proven above, it is not needed really and doesn't help much (unless you require emissions testing in your state/province) and you can just run a non-AIR cat (tube blocked off, although some cats are built with no AIR injection system in mind I believe). That's what I did and it stinks WAY less (it is not really that much quieter really than a gutted cat).
Car: 1987 Trans Am
Engine: 5.7 V8
Transmission: Automatic
im kinda worrying i should get aftermarrket header with air like is
http://www.ebay.com/itm/370615087592...84.m1423.l2649
or i can without air syetem?
http://www.ebay.com/itm/82-92-Hooker...da494c&vxp=mtr
i live in mass had inpenstions test every years..
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah I meant lean, sorry. My air injection system was running perfectly fine, but it wasn't even hooked up to the cat because the PO put a non a.i.r. cat on and it still passed emissions so I ripped all that stuff out, and the a/c(don't need it in Oregon). Like I said, I only noticed an increase in performance. I've also heard that the stock programming is very rich, so leaning it out by taking out the air system doesn't seem like a bad idea. I've also checked my spark plugs and they look perfect.
The parasitic drag on the smog pump isn't a whole lot, unless the pump is somewhat seized. The spots where it would lean out is only when the 02 is commanded to port, and we're talking such a minor different in fresh air flow.
This thread should have died years ago when we started it. It is more theory than anything.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
When I lived in Mass, the attitude of the inspection stations were simply that if it passed smog on the treadmill, it was OK. I always ran headers with no air, no egr, and a single high flow CAT.
Now I live in New Hampshire, and our laws are very hot-rod friendly. We're allowed to REMOVE our CAT, AIR, EGR, and EVAP system once the car is 20 years old.
-- Joe
I went from being able to not chirp second to being able to chirp second, so around 10 hp just for the air injection system. overall around 20-25ish because I took out a/c and ran a shorter belt.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Dakota W.
Yeah I meant lean, sorry. My air injection system was running perfectly fine, but it wasn't even hooked up to the cat because the PO put a non a.i.r. cat on and it still passed emissions so I ripped all that stuff out, and the a/c(don't need it in Oregon). Like I said, I only noticed an increase in performance. I've also heard that the stock programming is very rich, so leaning it out by taking out the air system doesn't seem like a bad idea. I've also checked my spark plugs and they look perfect...
Well I couldn't tell you how, but I'm getting 2 more mpg,it accelerates faster, and now I have alternator whine so it sounds like a maggie under hard acceleration
Edit: Also, what is a 7730? OH! and my exhaust stopped popping as much when I downshift with air taken off.
.Edit: Also, what is a 7730? OH! and my exhaust stopped popping as much when I downshift with air taken off.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
P.S, A stock L03 with a 5 speed can chirp second and third no problem. Heck, a chevy aveo (110hp) can chirp second and third.
When you can lift both front's off the ground, is when things get interesting...
-- Joe
I need a tach, mine doesn't read accurately, so I'm probably 1-1500 rpms below what it says. If I had a proper tach I'd know for sure lol. I'll try and chirp 3rd on my way to class today then.
Also, the way I understand the a.i.r. injection system to work is that it warms up the cat so it can burn the exhaust more efficiently when it's cold, and it also injects into the exhaust manifolds. Mine was only hooked up to those 2 things, it had nothing running to the intake whatsoever. There is no way the car could run leaner or richer because the A.i.r. system is purely for exhaust.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Isn't slightly lean better than slightly rich anyway? That's why turbos are effective, they cram as much air into a cylinder as possible, so in a sense leaving the stock programming the way it is would mean more air for combustion, I don't see how that would be a bad thing if there is no sign of detonation or overheating.
Edit: Also, what is a 7730? OH! and my exhaust stopped popping as much when I downshift with air taken off...
Isn't slightly lean better than slightly rich anyway? That's why turbos are effective, they cram as much air into a cylinder as possible, so in a sense leaving the stock programming the way it is would mean more air for combustion, I don't see how that would be a bad thing if there is no sign of detonation or overheating...
Edit: Understand that the saying "leaning it out for more power" implies getting it closer to 14:7 (stoich) from already being in a rich state, not from already being in a lean state...
Alright I'm confused. Popping is caused by running too lean. But removing the air pump is supposed to make the car run leaner, but I was already running lean and it made the car run richer by introducing more air to the equation? Please correct me if I'm not accurate.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The job of the ECM is to add fuel at the appropriate RATIO for the measured incoming air.
If you lie to the ECM about how much air is being measured, then your target AFR is off.
What AFR is correct is dependent upon the application. Some combos make more power at 12:1 than 12.5:1 than 11:1 AFR. Lot's of variables as to why, cooling through fuel, atomization, etc.
-- Joe
Alright I'm confused. Popping is caused by running too lean...
But removing the air pump is supposed to make the car run leaner...
... but I was already running lean and it made the car run richer by introducing more air to the equation? Please correct me if I'm not accurate...
I'm coming to an understanding that if your engine runs with a good a/f ratio removing the air system without a tune will not hurt it, but if your engine has pre-existant problems you should definitely tune it to run without the air system, or fix the problem if possible.
I'm coming to an understanding that if your engine runs with a good a/f ratio removing the air system without a tune will not hurt it, but if your engine has pre-existant problems you should definitely tune it to run without the air system, or fix the problem if possible...
Bingo! Also, removing the AIR pump eliminates clutter, but gives no real performance gain other than a slight weight savings. Your air/fuel is your air/fuel, without or without the AIR pump, so we only need to give the engine what it wants. Correct, if your exhaust is popping, but immediately stops when the AIR pump is removed, it is due to a pre-existing problem, and not the pump. If anything, popping with the AIR pump installed should confirm that the pump is doing its job and providing additional air...
Car: 1987 Trans Am
Engine: 5.7 V8
Mass dropped emissions inspections on pre-96 (now I think pre-98) vehicles in October of 2008. While technically there is still a 'visual' inspection, I can't imagine a station really picking on a 25-30 year old vehicle for missing smog pipes.
-- Joe
-- Joe
im thinking do same thing my trans am lol..
i wonder u can help me out to replaced the header at ur shop or whatever u had.. hope u can and i can get hooker short header with y pipe too..
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
YEA same thing i thonght so.. i were owned 1988 ford crown vic i replaced aftermarket headers passed inspection in NH and never complain abt exhuast... they saying car is old and nothing do with it..
my KARR has all the smog pump stuff gutted and the egr blocked off with a nice anodized block off plate.
Car: 1987 Trans Am
Engine: 5.7 V8
Yea man. Need power sound from header lol.. I have new high flow exhuast on my car now. Good thing only need header and y pipe
