Can i run my engine w/o A.I.R. system?
Old Jun 17, 2012 | 08:43 AM
  #301
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Can i run my engine w/o A.I.R. system?
Originally Posted by ivanhoe RS
Just wondering if it would set the engine light off with that air control not hooked up
what year and motor do you have?
Old Jun 17, 2012 | 09:55 AM
  #302
ivanhoe RS's Avatar
its a 1988 rs 305
Old Jun 17, 2012 | 10:00 AM
  #303
ivanhoe RS's Avatar
i ripped a 3 inch exhaust off my 85 camaro 350 carb but it had no air control on the headers so its gone on my 88 rs now just wanted to no if that would my engine light off ?
Old Jun 17, 2012 | 11:06 AM
  #304
KITT1983's Avatar
unplug the electrical connecter on the A.I.R. diverter valve. to see if a check engine light comes on
Old Jun 17, 2012 | 02:17 PM
  #305
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I THINK it does if you remove the egr, but my light didn't come on when I removed the a.i.r. system.
Old Jun 17, 2012 | 03:33 PM
  #306
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
I have had mine removed for a while and no check engine light
Old Jun 22, 2012 | 04:17 AM
  #307
Eclipsegs621's Avatar
Car: 84 Camaro
I know im probably beating a dead horse but I got a 84 camaro with the A.I.R system partially gone and the tubes off the exhaust manifold were rotted so I plugged it up. Does anyone have pics and/or instructions for the whole removal process? Im trying to get the car running again. Any help would be greatly appreciated.
Old Jun 23, 2012 | 03:23 PM
  #308
Dakota W.'s Avatar
You need a catalytic converter without the air tube on the side first off, then you just start unbolting stuff, you're also going to want a smog pump delete pulley otherwise the pump will seize and shred your belt.
Old Jun 23, 2012 | 05:21 PM
  #309
PUNISH3R's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
Yeah, I ripped all that stuff out for maintenance
Sounds sick!!!!!
http://www.youtube.com/watch?v=B8hMcheFRkA&feature=plcp
Old Jun 23, 2012 | 06:35 PM
  #310
Car: 84 Camaro
I don't have a serpentine. I need the vacuum diagrame for the complete job with out smog pump if anyone has it
Old Jul 3, 2012 | 01:31 PM
  #311
b3x87's Avatar
Car: 1987 Trans Am
Engine: 5.7 V8
Transmission: Automatic
Sounds sick!!!!!
nice i love that sound!!!!!!!!!!!
man i wish my car dont have air. for sure i get header now!! but i have AIR on my car ugh and scared to removed themm
Old Jul 4, 2012 | 12:02 AM
  #312
Dakota W.'s Avatar
Sounds sick!!!!!
Is that blue smoke I see? No bueno amigo!
Old Jul 4, 2012 | 01:44 AM
  #313
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I ran a new, shorter belt to run w/o A.I.R
Old Jul 4, 2012 | 02:11 AM
  #314
Dakota W.'s Avatar
So did I. But it sounded like he wanted to keep his belt so I didn't bother telling him about running a shorter belt.
Old Jul 5, 2012 | 07:59 AM
  #315
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Sounds sick!!!!!
Idle sounds great. I wonder if you could find a way to eliminate that tin like noise when you get on it?
-- Joe
Old Jul 15, 2012 | 03:01 PM
  #316
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
I didn't go with an AIR delete pulley, been running the pump for 2 months now with no problems. Fasteddi has had his AIR off for years and years without a delete, with no seizing up of the pump. If it does seize up, I'm just going with a shorter belt. Hopefully I have luck like Fasteddi though, and it lasts. What would cause it to seize up, anyway?
Old Aug 7, 2012 | 10:48 AM
  #317
AMEcustom's Avatar
Car: 85 IROC
Engine: 305 H.O
Originally Posted by onesmartidiot
Seems all of these posts are mostly relevant to tpi/tbi setups. I just started this on my 4bbl 305 yesterday. There are a ton of vacuum hoses going from the carb to the various a.i.r components, do I just block these off?
-Blain
I have the same question? Does anyone have the answer? Please help the new guy out!
Old Oct 29, 2012 | 08:28 PM
  #318
Duggs 71's Avatar
Engine: 91 RS Camaro T-Top
Axle/Gears: Standard
Hi Guys, not sure if im posting in the right place (new - old person). I've recently purchased a 1991 RS 305 Carby Camaro. Bit of a project for me and my two pre teen sons.
I want to go old school on it with Headers and a big chrome aircleaner. When i looked at the stock exhaust it had tubes running out of them and reading here it sounds like this AIR system. (We had nothing like this in the 70's and 80's when i was working on cars). What is the process for removing it.
Also what do i have to do to remove the stock air cleaner setup and replace it with the big chrome aircleaner?
Thanks in advance for any help here.
By the way i live in New Zealand and the emission laws are exempt for all "Classic" American Muscle cars, so i can pretty much just go with straight pipes if i want.
Cheers
Old Jan 29, 2013 | 09:43 PM
  #319
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i to would also like to know what would cause the air pump to seize up? how does the pump know you don't have the tubes hooked up? makes no sense to me.
Old Jan 29, 2013 | 09:59 PM
  #320
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Because obd1 systems are like cavemen, the pump is just that, a pump its driven y the belt and its sole purpose is to push out air, there's no post catalytic converter sensors so as far as the car is concerned everything is normal. I've had my pump off for 3 and a half years now. The only thing that would cause the pump to seize is failure, parts wear and by spinning it as a pulley you're just doing the same thing as if it were still hooked up, the life expectancy of the part remains the same
Old Jan 29, 2013 | 10:15 PM
  #321
Car: 91 formula
thanks. I assume your running the delete pulley or did you just run a shorter belt without pully. I still can't decide if i want to go with the delete pulley way.
Old Mar 6, 2013 | 12:55 PM
  #322
Car: 91 formula
Btw. I did go with a delete pully just for a cleaner looking engine bay. But i to trim down 1/4 an inch to fit it on the air pump bracket. Just thought i would share that if anyone else needed help.
Old Mar 27, 2013 | 08:52 PM
  #323
jay86TAsmith's Avatar
Car: 1986 Pontiac trans am
Engine: L69 305 H.O.
Transmission: Norg werner T5
does anyone know about mine its got a 4 barrel carb not tpi and i took mine off to get to my plugs will it hurt mine if i leave them off and just block off the holes?
Old Apr 16, 2013 | 03:23 PM
  #324
Bobby Goff's Avatar
Car: 86 Camaro Z28
Transmission: TH 700R4
ok question.. may be a tad off topic but it sounds like someone here will know- any idea what size bolt is holding the air crossover tubes on the engine on each side? on the passenger side it looks as if it holds the tube from the cat on too... thanks
Old Oct 10, 2013 | 06:43 PM
  #325
PawZ28's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Originally Posted by Kevin91Z
I dont understand your question. What do the fuel pressure regulator and the ECM have to do with removing your AIR tubes? Nothing that I know of.
The truth is you can remove your AIR pump and AIR lines with no problems to the computer. However its completely illegal to do so in the eyes of the law. If you can live with dirty air, go ahead, but the person behind you might not.
I think it is really funny that people think that the A.I.R. system helps with emissions. It is a farce.
Old Oct 10, 2013 | 07:22 PM
  #326
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
It does help. With the cats on, the exhaust doesn't smell so rich.
Old Apr 24, 2014 | 07:51 PM
  #327
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
I removed the main components of the A.I.R. system today to prep for header install. From what I can tell, all it does is push air back into the manifolds/headers to dillute the exhaust to "appear" cleaner on a sniffer test. The same amount of Hydrocarbons are still emitted from the exhaust, but at a "leaner" level due to fresh air mixed with it.
I could be dead wrong however . . .
Old Apr 24, 2014 | 08:11 PM
  #328
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
basically lol.
Old Apr 25, 2014 | 11:09 AM
  #329
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't think you understand the volume of exhaust in CFM vs that little pump. To be able to dilute the mixture that much, that your PPM is greatly decreased would require a small blower!
It helps COMBUST the left over elements in the cat.
-- Joe
Old Apr 25, 2014 | 01:19 PM
  #330
VincentZ28's Avatar
-- Joe
Your gonna wish you would have kept all that stuff on there. Your eyes will start to burn and your clothes will stink
Old Apr 25, 2014 | 01:23 PM
  #331
VincentZ28's Avatar
Oh by the way, we did a test on the Dyno with and without the smog stuff connected and there were no power loss. Just a myth!
Old Apr 25, 2014 | 01:38 PM
  #332
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Do you make 600 hp ?
-- Joe
Old Apr 25, 2014 | 02:51 PM
  #333
VincentZ28's Avatar
-- Joe
I wish
Old Apr 25, 2014 | 03:13 PM
  #334
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I wish
well I figure, with the turbo, 412" engine, reverse manual valve body on a 3 speed automatic, and 600+ hp with 700+ potential, emissions stuff isn't really part of the design.
-- Joe
Old Apr 27, 2014 | 08:34 AM
  #335
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
-- Joe
Well, like I said, I could be dead wrong, and looks like I am hehe. Thanks for the info.
I've driven it for a couple days with the A.I.R. system removed, and I don't notice anything adverse or negative, which to me is a good thing. *I* see it as an unnecessary system in my personal vehicle, so I decided to simply remove it. I would like to think that if it was so important and critical to engine performance, all aftermarket headers would be required to have the A.I.R. ports on them.
Now I don't know much of anything about catalytic converters, but are the ones made today a newer/different design than the factory ones on our cars? Would a newer design cat be more efficient in doing its job, therefore possibly eliminating the need for the A.I.R. system?
Second part to that question, is a faint smell here and there of rotten eggs (basically smelling CO, right?) a sign that the cat is in need of being replaced? I've noticed a few times even before I took out the AIR system.
Old Apr 27, 2014 | 10:22 AM
  #336
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
CO has no odor. If you're smelling rotten eggs, that is due to sulfur which is one if the things the cat and air system were designed to reduce.
Old Apr 27, 2014 | 10:28 AM
  #337
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Gotcha. So is that a sign of a failing cat? Like I said I've noticed that sulfer smell for a couple months now, long before I removed the AIR system.
Old Nov 2, 2014 | 02:42 AM
  #338
88gtadan's Avatar
Car: 1988 Pontiac gta
Engine: 5.7 tpi
Axle/Gears: Borg Warner 3.27
I have been wanting to do this for awhile now and finally broke down and did it. I love the engine bay a lot better now. I did find some plugs that I will be using on the remaining air tubes still sticking out.
Attached Thumbnails Can i run my engine w/o A.I.R. system?-img_1343.jpg   Can i run my engine w/o A.I.R. system?-img_1339.jpg   Can i run my engine w/o A.I.R. system?-img_1336.jpg
Old Mar 2, 2015 | 10:50 AM
  #339
Metalizer's Avatar
This is just the info I was looking for. I just picked up a 86 z28 and it seems the previous owner did a half *** job of trying to remove it all.
Old Mar 2, 2015 | 01:05 PM
  #340
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The main question is this:
Do you need to be smog tested where you are?
if not? Then yes, the car will run just fine without the AIR system hooked up.
Old Mar 3, 2015 | 06:17 AM
  #341
Metalizer's Avatar
Car only requires its annual safety inspection here in Texas due to the age of the car.
Old Mar 3, 2015 | 06:20 AM
  #342
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Just make sure that the inspection doesnt also require a visual check of emissions equipment.
Old Mar 3, 2015 | 08:29 AM
  #343
Metalizer's Avatar
When removing the AIR system, do I remove the charcoal canister and these crap vacuum lines as well?
Old Mar 13, 2015 | 01:29 PM
  #344
chops1sc's Avatar
Car: 2011 Silverado LTZ, 91 Camaro RS
Engine: 5.3L (LTZ), 3.1L (RS)
I can sometimes smell the rotten egg odor on my 91 RS 3.1L V6 and I still have everything stock. Not very often but it seems to happen more when I get on it pretty hard rather than normal driving.
I am going to try a smaller belt and block the lines coming to and from the pump. There is a thread in the V6 section, specifically this post: https://www.thirdgen.org/forums/v6/6...ml#post5674560
Old Mar 18, 2015 | 12:42 PM
  #345
92RS_Ttop's Avatar
Car: 1992 Camaro RS
No, they are a completely separate system from the AIR pump and cat. You'll want to keep the charcoal canister and it's vac lines. They collect excess fuel vapors from the gas tank and allow the engine to burn them off. I never had an issue, but lots of people here have noticed a strong gas smell after removing the charcoal canister and vacuum lines.
And FWIW, I put them back on the car when I swapped in the V8.
Old Mar 18, 2015 | 01:33 PM
  #346
Ozz1967's Avatar
Car: 1984 Trans Am
because I'm sucking fuel up from my tank through the canister, I blocked off my cannister lines and plugged all the ports. No gas smell here and the car runs fine. This may be my situation though, everyone seems to report a different answer on what happens when you pull the charcoal cannister.
Old Mar 18, 2015 | 01:41 PM
  #347
Ozz1967's Avatar
Car: 1984 Trans Am
I'm pretty sure the fuel vapors come if you vent your tank strait to atmosphere.
Old May 17, 2015 | 06:23 PM
  #348
Breezevaflowin's Avatar
is there a diagram or step by step instructions to reinstall the smog pump an its componets i need it fora 86 camaro 4bbl carb it needs to pass cali emissions ty in advance i need this asap plz
Old May 18, 2015 | 12:52 AM
  #349
Dougy89's Avatar
Car: 1989 Firebird coupe, 03Holden VY SS
Engine: 305 TBi & LS1
Transmission: TH700R4 and Tremec T56
Axle/Gears: 10 bolt 2.73 open, LSD 3.46
Anyone got any handy tips for removing the torx bolts on the smog pump? Mine are stuck solid and driving me mad... needless to say after several goes one is now starting to round out so i bolted the pulley back on and drove on.... no room to use power tools etc in there either...
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
