Can LS1 Cat-Backs be moddified to fit on third-gens?
Old Jan 4, 2004 | 04:39 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Has anyone done this and if so how hard is it? BTW I have no cat to worry about, and system will be welded to y-pipe.
Old Jan 4, 2004 | 05:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sure. The rear ends on both gens are almost the same. It will not be a direct fit, but you can weld and modify it to fit.
Old Jan 8, 2004 | 09:55 PM
Camaro_nut's Avatar
Do a search. I'm sure some people here have done it,
Especially the SLP 'loudmouth' exhaust. It will fit to a
thirdgen, but you will have to modify the hangers to
fit in place.
Old Jan 9, 2004 | 01:32 PM
Marc 85Z28's Avatar
The only thing you need to modify is the inlet to the I-pipe so it fits the cat. The hanger is the same on the passenger side near the muffler inlet. You must make a hanger for the driver's side near the muffler exit. Everything from the front of the driveshaft back is the same. I have a Mufflex off a 99Z28 on my car.
Old Jan 9, 2004 | 07:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
My 4th gen and roomates 4th gen have different hanger locations. He has two per side in different spots on his 02 SS and I have only one per side on my 95Z. I think it depends on the system. Then again he has the factory option center exit exhaust from SLP so they maky come a bit different for that reason.
Old Jan 10, 2004 | 03:57 PM
my88IrocZ's Avatar
I had a 4thgen SLP Loudmouth on my 88' Iroc-Z 350 before I sold it, It sounded awsome I thought. I did take the resonator on the loudmouth out though and put a XR1 borla muffler in instead, it gave it a nice deep sound.
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
utfan01ss
Sep 28, 2015 12:17 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
M&M_GTA88
Mid-Atlantic Region
Sep 5, 2015 05:00 AM
