making an exhaust
Old Jan 6, 2004 | 07:03 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
making an exhaust
hey i want to get headers for my v6 that bolt up to the factory y pipe but if that isn't possible i am going to use manifolds. My question is can you put a cat right after the y pipe and then muffler right after that or should there be some space. Also what muffler should i go with i was looking at the 50 series flowmaster but don't know if they are too loud. i mainly want it to sound like a v8 when i rev it and be able to hear myself think when crusing Thanks Eric
Old Jan 6, 2004 | 08:19 PM
bes217's Avatar
The only headers that are available for our v6 cars are custom ones. Unless you are able to score some hedmans like I did. None of the header choices will bolt up to the stock exhaust so you will need to get a custom y pipe. I had one done for like $150. If you get headers and a y pipe then you might as well get a catback to see better gains. The dynomax is generally preferred for the V6'ers and is pretty cheap. Only like 180 or something from summit.
Old Jan 6, 2004 | 09:49 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may still want to dump the exhaust further down the back of the car. Dumping it right where you want will still be loud because of its location in relation to the passengers.
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
