What Length header bolts? SLP's
Old Jan 10, 2004 | 05:16 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
What length header bolts is eveyone using with SLP headers? I know on the bolts with the offset I have to use the stock bolts but what about the others? I bought some 1" bolts and them seem to short with the gaskets. I did a search but cant find anything....heres a picture of the 1" bolts going thru the flange and the gasket, doesnt look like enough to thread, or is it just me?
Old Jan 11, 2004 | 12:33 AM
MdFormula350's Avatar
i am using the one that came with the install kit.
Bolts, Header 3/8" - 16 by 1"
http://www.slponline.com/view_produc...RTNUMBER=30034
and using the rest of the stock stud type bolts.
Old Jan 11, 2004 | 09:36 AM
so the 1" bolts were plenty long enough? from what I measured only about 3/8th would be going into the head, is that plenty to use?
The bolts that your using are the exact same bolts I got. The 12 point bolts....so you had to have had the same amount going into the block, huh? and that was enough to get a good grab and torque them down?
Old Jan 11, 2004 | 09:49 AM
heres a pic:
I may go back and get 1" 1/4 cause I was going to put a lock washer on the bolts too.
Old Jan 11, 2004 | 01:26 PM
i guess they were enough, i mean nothing stripped on my heads, and the headers went down tight. i dont have any leaks that i can tell.
midge54
Dec 27, 2019 04:14 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
