replaced 02sensor but still ses light
Old Feb 16, 2004 | 07:14 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
I replaced it the other day and disconnected the battery to reset the computer but i'm still getting a ses light. any sugestions?
Old Feb 16, 2004 | 11:02 PM
MdFormula350's Avatar
just to make sure post the code you are getting?
the way it sounds is that u found what the code is and tried to fix it.
so i guess maybe it has to be the connection or the wire if it is the o2 sensor code ur getting.
Old Feb 16, 2004 | 11:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is the code that you got?
Old Feb 19, 2004 | 08:57 PM
ZROC86's Avatar
Transmission: A4
I hooked up our schools little handheld thing we use and didn't get any trouble codes. It said I may need a TPI adapter cable so it may not have read correctly.
When I had the handheld connected and the car running the light wasn't on. But when I took the car back to the parking lot it was on. WTF?
Old Feb 20, 2004 | 11:56 AM
Marc 85Z28's Avatar
You don't need a scan tool. Just use a paper clip to jump the upper right 2 terminals with the engine off. The check engine light will flash your code.
Old Feb 21, 2004 | 03:47 PM
ZROC86's Avatar
Transmission: A4
I did the jumper thing. It flashed once paused and flashed twice.
Old Feb 23, 2004 | 04:26 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
So it went *bling* pause, *bling-bling* long pause and repeated itself? If so, that's the normal Code 12, it suposed to do that three times, then flash whatever else is messed up, three times, then it goes back to flashing 12 again, three times. If all it does is flash 12 at you all day long, then that's it, no trouble codes anymore.
Old Feb 25, 2004 | 03:47 PM
ZROC86's Avatar
Transmission: A4
I did it again and got what I think is code 36 and 45.
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
