Jacking Engine and sensor
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
What is the correct way to jack a motor to get headers to fit? And what is the sensor on the middle passenger side of block?
Transmission: 4L80E/4L80E
Putting a flat board across the bottom of the oil pan and using a floor jack works.
That's the knock sensor.
The more level it is, the better, but I've done it as described.
Car: 91 Camaro RS
Does the knock sensor just unbolt out? Will I get a SES if I did break it/ mess it up? Thanks
It unscrews. Turn it from the hex on the base, not by the body.
