hedman O2 bung location
Old Mar 15, 2004 | 11:22 AM
91Z28-350's Avatar
I got these from Jet-Hot...part # 68491...are the O2 bungs in the right location? I had one welded on the passenger side facing towards the front when I ordered it, but the driver's side looks backwards. I'm not sure if I'll have enough clearance, as I haven't installed them yet.
Old Mar 15, 2004 | 11:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the hedmans i have are non emissions ones.. i had to weld the O2 bung on myself.
because the collector is so low, the O2 would hit the k member on the drivers side if it remained on the front side... so the drivers side header has the O2 facing the rear, toward the oil filter.... more then enough room all around in that location..
does that help?
Old Mar 15, 2004 | 01:02 PM
91Z28-350's Avatar
Yeah, it does and is what I figured. Man, I don't know what's going on, it seems like one problem after another. Definitely not a satisfied customer....I guess I'll find out for certain once I bolt the thing on, but I don't forsee it clearing the k-member like you said.
Dialed_In
Aug 20, 2015 01:45 PM
crrllmich
Mar 27, 2013 09:58 PM
