!air
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
!air
i am going to be deleting the air from my 91rs and at the same time i want to take the air tubes off my manifolds but i am not sure what size plugs i will need?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: !air
Car: 1991 RS
Re: Re: !air
Originally posted by ShiftyCapone
A quick search shuld give you your answer. I think it is a 1/4" npt brass fitting but I may be wrong. Good luck getting them off. You may be better off just capping the top and leaving the individual pipes alone.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
couldnt you just plug it off at the check valve i know it wouldnt be the cleanest looking thing but technically it would work right?
Car: 1991 RS
well i just removed the tubes from both manifolds today and i want to order the plugs in the next day or so but first i want to make sure that it is 1/4"plugs i need
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Re: Re: Re: !air
could anyone double check to see if what size plugs i would need?
Car: 1991 RS
Re: Re: Re: Re: !air
Originally posted by Justin89Formy
1/4" brass pipe plugs. Sold at Autozone for about $.14 a pop
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Qucik question tho, why waste the time to do all that? Aside from a somewhat "cleaner" engine bay, there is NO advantage to removing it, especially with a stock exhaust manifold.
Car: '90 RS
Engine: 377 LSX
Car: 89 formula 350
I did it because:
1.) Car doesnt care if I rip it off...
2.) Little less weight, little more power
3.) I got big arms and it was MUCH easier to change the plugs with the tubes off
Axle/Gears: 3.23:1
I did it because:
I did it because:
