Some AIRy stuff
Old Mar 18, 2004 | 04:19 PM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
Some AIRy stuff
For those of you that have pulled the EGR off of a 3rdGen-
I believe I read this before, but I couldn't find a search thing on it. I took one of my stock exhaust manifolds down to Home Depot today and tried to find some sort of plug, hex bolt or whatever, to replace the places where the pipes connected to the manifold. I messed around with stuff for a while, and the closest I found was a 1/2x1 bolt. It doesn't fit all the way into the threads- I'm guessing it needs x1/2? Anyway, they didn't have any metric size things there so I'm wondering if I had the wrong size diameter or something. What size could I use for them, or did you find a way to cover where the piping connected to the hose? Or is there a better way to go about this?
Also, I can't find where the system connects to the intake manifold like everyone's been talking about. Can someone explain it for me? I'll go look at it again later. I haven't really inspected it or anything.
Old Mar 18, 2004 | 04:44 PM
Chevero's Avatar
I used a standard 1/4 NPT pipe plug. I found some short ones with recessed allen heads, and they look good.
Old Mar 18, 2004 | 08:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Some AIRy stuff
It doesn't. Check out this thread where I laid out the entire AIR system off of my car.
https://www.thirdgen.org/techbb2/sho...hreadid=228712
Old Mar 18, 2004 | 08:43 PM
Car: 85 Trans Am
Alright, that helps a lot. Thanks.
Old Mar 19, 2004 | 06:26 PM
Car: 85 Trans Am
One more thing, I don't think has been addressed blatantly yet, what do I do with that (O2?) pipe that goes down to the cat?
Old Mar 20, 2004 | 02:25 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Cut it at the cat, weld it shut, or have a friend/shop do it
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
